Click on my forsale link below for many shots... :laugh:
Thanks mate....
Very good shots so far guys, please try not to use your phone unless its 3.2mp or more.....
Thanks
Llynden
Edited by Hotr34
  • Replies 159
Ok people slow ya row... I need some new shots, the ones you have sent are good but what i need are single shots with a nice back ground for example...
TIPS:
Try to get down low and turn the camera on a slight angle and get the Car in the whole photo. do the same from the back.
So next time you go for a drive and find a nice spot, good chance to play with your camera.
Dont forget to turn your wheels for the perfect shot.
Another good photo is reflection from water after rain, again down low and get the reflection of the car in the wet concrete, works really well.
The use of sunlight is very important to show off your sexy paint job, make sure there are no shadow's over the car when taking the photo.
Look forward to your work
Llynden
Edited by Hotr34
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
