$200k?
Ah, nope. As they say on TV... higher!
BTW - the GT will be outside the Eurpean Cafe on Spring St next week from 8am to 9.30am (weather permitting)
Come and say hi!
{TUBZ}: If you can get either one for 200k, let me know. Would make a great investment me thinks :rofl:
Noice GT James, very nice indeed! Come and give it a squirt past my house sometime :P
OMFG!!!! that mclaren f1 everyone is going on about came into my work on Monday morning....i thought i would never live a day to see that thing and yes i took a photo {almost got fired for that} and i cant send it to the pc because i cant find my data cable and the mms bullshit wont let me send to my email.....but yea it is sexy.....i showed one of the guys from p1
cheers moe
just picture me staring at it for like 30 mins without doing work and snaping photos and you were the boss wat would u do??
Join you with a couple of beers in hand :blush:
ahahaha...exactamundo! I wouldnt fire my employees if they were gawking at a hawt car...plus its good to have a break...one cant keep working for 8 hours straight..... :)
Enzo and F50 at Ferrari today.
Sat in both. So f*cking cool. F40 still the bestest.
My modern Ferrari supercar trifecta is now complete.
I can rest.
BTW - had a multi-million dollar showroom this morning - pretty cool!
At 9am I had the following toys crowding for space...
Ferrari F430 Spider
Lamborghini Gallardo Spyder
Mercedes Benz SL65
Bentley Continental GT
Porsche 996 GT3 CS
Ferrari 348ts
Ford GT
Audi RS4 Avant
Porsche Cayman S
Ariel Atom
and the Smart car.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
