just about 10 mins ago (its now 3am) a black R32 on p plates...rims, zorst, looked like an aftermarket FG or CF bonnet on springvale rd.
i was in my mates CA 180, with 3 other blokes...
top blokes to have a chat to!
and the owners R32 went pretty hard! has SAU stickers on it...
pm me if your on here, im from glen waverly...
yeah i havent posted in this topic for a while but it was supercar sunday for me so i might share.
Saw the lotus club doing the rounds through reefton area, as well as the Ferrari club. maybe they had a joint cruise or it was coincidence. but it was awesome seeing soo many red ferraris on trip.
then i saw more Ferrari's, red in colour, yellow in colour, one driven by balding man showing his shiny patch and giving his car a bit of a stick, and bald man hiding his shiny patch with a Ferrari cap and jacket. spider/convertable Ferraris, new and old soo many prancing horses that youd think that they are a new taxi ;-)
what delorean?! pics dream car god damn so excited!
looked exactly like that :teehee:
never knew those cars were wide - but it looked very very wide - and in mint condition too
dont think it would be a supercar, but its one that is very rare
looked exactly like that :D
now figure who it belonged to :D
http://www.ozdelorean.com/
Saw a black countach on Sunday which looked just like this. The funny thing is how small these things are in real life - especially the rims. 15" rims are tiny by todays standards. Although 12" wide is still massive!
Saw a black 2 dr Maserati. Must be new as i hadnt seen this shape before and it looked mint. Had the licence plate GZ or something.
That and the 575LM that is in the apartment block next ot me these days...full of little add ons that makes me think the LM is a limited run of them or the owner used to be an EVO owner :D
Actually have a quick look at their website it was a Granturismo...great looking car. Easily tyhe equal of the DB9 in the look sdepartment
were the plates RUN4IT?
seen him around my area a lot recently... he likes to give it a boot too:)
TB - the Mas is Bobby Zagame's personal Gran Turismo. Plate = BGZ
It's just stunning!
The 575LM is the race car. 575M is the standard name for the upgraded 550 Maranello. Is it black?
Might it be Steve Snowdon's club car?
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
