every time i see one of those things it reminds me of my time working on the race version
easily the WORST and most frustrating racing car I ever worked on
I remember the Lamborghini personel having a discussion in Italian "how did those dumb Aussies manage to get that shitheap on the front row of the grid !"
We out qualified all the gun Lambo teams from overseas.
funny how the 'team' has moved on a little since 1998..
Yep Ash that is the one although the blue looks a little darker in real life.
I saw it too (sat on the doorsill ;) ) and used to chat to the owner, when I saw it was a bright sunny day and so was quite a light smurfy blue - I have a vid of it somewhere from years ago as it drove past and beeped at me.
An F40? Really? Did it look genuine? Never seen one in Melb before. You're very lucky.
I had my doubts when it was coming towards me but then it passed me it sounded like sex on wheels and it looked like sex on wheels my jaw fell out the window and i had a massive bulge in my pants. tried to grab the next u-turn but i was then hit by a red light so i could catch up to it and drive beside it.
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
    • I do this, I also don't get the joke
    • Return flow cooler will be killing you I reckon. You can certainly push more through a low mount setup but they're good numbers for a stock looking engine bay.  Mine made 345rwkw (hub) at 22psi on 98 with a "highflow" on a stock manifold but it's a long way from a normal high flow or standard engine. I used one of those Turbosmart IWG-75's and it was great with the Motec running closed loop boost with pressure being applied to both sides of the diaphragm.
    • Hey man do you have pic of adaptor plate by any chance I need to match up the bolt holes as my gearbox adaptor plate ones are way off the only bolts of starter motor are matching thanks
    • Do they always do it from the AFM? If so... You know what I'm already thinking I reckon...
