i have not had the chance to dig around in the shed yet guys but i wil endeavour to do it tomorrow nite and see what i can find.
i have just finished a 14hr day and will be another 3 in a row the same so please bear with me k :D
cheers oxford
They're handy if it's a cold and rainy night, and the inside of the car is getting steamy 'cos the heater is on. You can open the windows slightly and not have the rain getting in.
Heat + aircon = hot dry air, no fogging up :D
hiya again all.
the part numbers from local nissan dealer and pricing are as follows.
part# NI-G3800-0V500 Description ROOF VISOR price $268.40 plus GST which works out to be $295.25.
that is what i paid for them ex-japan on the 18/6/06 at local nissan dealership, took them around 4-5weeks to get here but saved a ton on freight charges.
cheers oxford
I'm mainly after a set because I'm sick of the wind noise I get on both sides when on the highway etc. I'm guessing this is because of the pillarless door frames. For you guys that do have them does it make a difference with the wind noise etc. And yeah cleaning my windscreen and having the water comming in was a pain but my FMIC fixed that....no windscreen washer bottle :)
Edited by Mr_RS4
still get a little bit of wind noise when in a heavy wind or have turned the wick up a bit on the back roads etc :(
but all in all they are a good investment as they give a lot of other benefits too
cheers oxford
http://page18.auctions.yahoo.co.jp/jp/auction/w10673072
they sometmes come up in Yahoo auctions if you have a
means of purchasing & delivery to Australia. The price
looks good too...
I have a passenger side set only if anyone wants to throw money at me. I dunno what they are worth so PM me with an offer if ur interested. I may or may not throw in a lap dance in my new sequined mankini....
edit - *SOLD*
*FEELS CRUSHED THAT LAP DANCE OFFER WAS REFUSED...*
Hey Phil.. Was that 1.8m long measured from one end to the other, following the curve?
If they were in a box, how long do you think it would be? 1.5m?
HI
They are 1.8m following the curve or 1770mm tip to tip
To put them in a box it would need to be about 1.8m L x 250mm W x 50mm D
I could see both fitting in a box this size with a bit of packing
Hope this helps
Thanks
Phil
  • 8 months later...
Hi There,
sorry to drag up an old topic but is it hard to fit these? I have managed to secure (if I want) a set and given Im missing a drivers side and suffer the normal problems (window down water running in, in mornings and wind/driving rain leakages) I would like to grab them and fit them. The ones I can get have no clips and there seems to be nothing on the car itself. Is the mounting hardware if any common fitting clips or are they stagea specific?
Thanks for any help you all can give
Kenny
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
