I'm looking to get an Alpine head unit and maybe some splits.
Where can I get a good deal in Sydney for such equipment?
I know of the usual suspects..
FHRX
JB
Strathfield
Lifestyle
Any others I should check out?
I thought eBay would be good but they end up being the same price as JB!
FHRX - not an alpine dealer to my knowledge
JB- sell alpine not the top end ger
Strathfield
Lifestyle
JB- sell alpine not the top end gear
Strathfield - not a dealer
Lifestyle - unsure
Precision car audio engineering do. the owner is ex alpine australia so he knows more than most about them
they are in carlton.
Stage Co. on 3rd Avenue in Blacktown is big on Alpine, Rockford, Clarion, etc.
The owner there is a top bloke to, helped me out with building a box for subs I didn't even buy from there!
Lifestyle is also the go for Alpine, but everyone I know that has been there has paid some big dollars for 'nothing special'
Life Style are like the Nike of the audio world... you pay for the name... unless its a custom install, i wouldn't bother, they can be beaten...
+1 for Precision
JB is pretty good, depends which one you go to though... Chatswood is pretty good, you can haggle the price down pretty well too...
here's something I found today:
precision current promo. bit cheaper than JB currently I see.
Leader_Retail_LR_8.07.pdf
Edited by Chris Rogers
wonder where they get alpine from. they are not listed as a direct dealer.
Thanks for all the suggestions guys.
Are these places generally open on weekends?
i have a 9853R and six stacker installed in car if you are interested in buying 2nd hand.
Thanks but I'm looking for a Alpine headunit with full speed iPod connectivity capability
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
