The manual gearbox in my R33 GTST has all the common crunches 1st to 2nd, 2nd to 3rd especially when cold.
I've tried new synthetic oil and Nulon which hasn't made any difference and my mechanic has suggested a re-build before something breaks and costs lots more.
I figure a 2nd hand box will likely have the same problems I've got now so I'll get it rebuilt.
Two questions
1) I've read elsewhere people only replace the synchros that are worn - this sounds crazy due to the expense of pulling the box out and the synchros are only ~$50-100 each - why wouldn't you replace them all?
2)should I swap the clutch at the same time - I've no idea how worn it is, but again, there's a lot of cost in pulling out the gear box.
cheers
Mike
https://www.sau.com.au/forums/topic/180308-worn-gearbox-options/
Starting to get the same problem in my box but it's only when going into second. I've gotta change my clutch soon so I will most likely do it at the same time to save on cost. I figure once it's out I might as well do all the synchros as it's gonna save me headaches later down the track
are any special tools required if you want to replace the synchros? like a press or anything like that?
thanks guys
how hard is it to see how worn the clutch is - obviously it needs to come off the flywheel to inspect the bits.
If it was ok (I'm assuming the key thing you're looking for is how much meat is left on the clutch plate), you'd still put a new throw out bearing in?
I'm trying to find the right balance of the cost of pulling the gearbox out and which bits should be replaced (given it's an import and I have no idea of the age or the treatement the car's had).
The other factor is I'd like to put a Jim Berry clutch in, but my mechanic won't warranty a clutch supplied by someone else (fair enough), and is recommending an Exedy (with 2800lb clamp pressure). I'm sure Jim warranties his clutches but it comes down to labour - if theres a problem with the clutch, my mechanic won't wear the time to pull it apart again.
My power is only 235 rwKW (R33 GTST) - so a Jim "full monty" is not required - I'll have a chat with Jim Berry.
The next question is whether I get the shifter re-built at the same time - again it feels OK, but once the gearbox is out...
cheers
Mike
Edited by mikel
ah someone with a r33 gtst turbo box issue like me ;) mine started off as a 3rd to 4th crunch then a sometimes 2nd to 3rd crunch, engine blew up similar time so got engine rebuilt and box reco'd at trade price from working in a mechanic shop, still cost me 1200.. box had done less than 12 months driving and same thing only this time it jumped out of 3rd gear while even lightly accelerating, pulled box out...AGAIN...cost me another 900 to fix, apparently 3rd-4th selector fork broke and this wore out something else etc.. u know what shit they dribble, anyway, my experience with the ever so apparently tough r33 box has not been goood, i had a excedy h/d in there before first rebuild then while engine and box got rebuilt i put in a hks twin plate, so far box is ok but only done 5k since been fixed...running castrol vmx 80...
I was just about to post the same question, I have a triple plate OS Gikon and am changing to a jim berry clutch as soon as he builds it, my box crunches into 4th most time (especially when giving it some) is it normally just the synchro's that need doing ? 1st 2nd never do it 3rd has maybe done it a few times (most likely my driving).
What does it normally cost to get these done roughly as the clutch will be going in soon.
cheers.
Ok I have got a price of 800-1000 to put new synchros in 2nd-3rd-4th gear, a new front bearing and some other bearings in the gearbox and a general cleanup, also removing triple plate clutch and fitting my new Jim berry clutch.
Thats at a place at the Gold Coast.
replace the clutch mate, whether its got meat on the plate or not, you dont know how old the pressure plate is.and if your thinking of rebuilding your shifter (i.e replacing the nylon components) why dont you buy a short shifter at the same time :D
edit: oh and try some redline super lightweight synthetic oil once its rebuilt etc, imo that will help your gearbox love a long and healthy life :thumbsup:
Edited by toffy
    • Nah, they'll do it without a receipt, tell em roughly when it was, that it was cash, youll likely only get store credit, but that gets you some dollars towards the newer better shovel, or other item you need/want later.   Still take it back and have a crack at returning it.
    • Nah. Was just wondering if you were having a small stroke or if there was some slur/gaf/inside joke that I wasn't aware of.
    • That was a fark up, it's Salamanca Place I was thinking of. And now I'm curious as to what potential slur/gaf I have caused with Salamander Road, ha ha!
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
