Nice pics... What an awesome trip!
You should've posted All of the pics in the supercar spotted thread, you would've won that game and probably destroyed the thread!! :wave:
P.S. Your angles are hurting my neck! :P
A few pics from Lambo :/
Lambo doesn't have a test track, so they test all the cars on the road in front of the factory... makes for some interesting sights! Pretty cool to be putting your hire car down the road and having a bright yellow Murcielago fly past on the wrong side of the road :cheers:
Some general France and German shots - including my whip, the new C220 CDI Mercedes.
It sat on 200 very comfortably - 225 was about the max, then it started raining.
I got out to the Nurburgring but couldn't get on the track due to a slight cleanup issue of an englishman, a 993 Carrera and a wall.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
