Hopw the hell do you do it?
I don't care if youc all me a noob etc, but i don't know.
I'm not talking about leaving 11's on the ashphalt.
I'm talking about how you keep the rear wheels spinning whilst stationary.
Thanks.
https://www.sau.com.au/forums/topic/181218-how-do-you-do-a-burnout/
OK, so basically...
On the strip, depending on whether your car is auto or manual...
Auto - One foor firm on the break and then other on the accelerator (try not to rev car above 4000rpm)
Manual - Dump Clutch to get wheels spinning, then begin to apply the break
On the street - Drive like a normal road user!!! save tyre shreading for the track....
none of this hoon behaviour shit as it gives Skylines a bad name!
Another way you can do it is hold the brake on with ur right foot then use your heel of your right foot to work the accelerator. Have the car in like first gear and hold some revs with your right heel then let the clutch out reasonably quick.
Use more or less brake with your right foot so that you hold the car still but not so much brake that you stall the motor.
Yeah but as above you are best keeping that to the track.
Na you dont use handbrake. Your skyline is RWD unless a GTR so you only want the front brake on to hold the car still. There is a thing you can buy called a line locker which connects up with the brake lines to stop pressure getting to the rear brakes so when u put you foot on the brake only the front brakes will work.
This is however not legal on street cars.
Ideally you want no braking on the back wheels so that you can do stoppies easyier.
the easiest way is the heel/toe trick.
just keep it at about 5000rpm. if you are running streety tyres there is no need to do a big smoke burnout. just enough to get the water off is all. if you are running slicks then you need to get heat into them so a bigger burnout is better. that is where changing into second helps. you get the tyres spinning faster which creates more heat.
the handbrake only works the rear wheels so there is no point using it for the burnout. you can use it to load the motor up on the start line though if you are in a manual.
i wouldn't try starting in second unless you have a good clutch or crap tyres.
well thats what i did for several minutes on a skid pan and looked back over the vidoe and it sounded like a noob who was just burrying the pedal...
at the drags u dont want to be bouncing off the limiter......its got noob written all over it......i know cause i used to do it....
OK, so basically...
Thanks mate.
And i don't do it on the street.
To be honest, i need to learn how to drive the car before i even start trying to act like i know how to drive.
The reference up there was just so you guys know what i meant :laughing-smiley-014:
Now i can afford it, i'll stick to the tracks and skidpans to be a HOON :)
dump 2nd gear, hit the brakes sit on 7,000rpm and shoot flames :).. thats if i do one that is :P
or if u wana look cool dump 1st play with it a bit, hit 2nd and limo for around 50m :D
www.youtube.com/lthlrb
Edited by LTHLRB
If you are in the wetbox its quite easy. No need to dump the clutch then reach for the brake pedal. Just heel and toe your loud and brake pedal, Lightly on the brake is all you need, second gear, a enough revs to be around boost and slip the clutch. If your diff works well you wont go left or right so concentrate primarily on your tacho. Just float the revs below the limiter till you feel the tyres start to bite. You are now good to go.
Dont snap your foot off the throttle, ease it off whilst taking your foot from the brake. Easier on the car that way.
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
