the only downside to Nistune is that it doesn't have any "real" inputs for engine protection such as wideband feedback for lean out, or pressure switch inputs for low fuel pressure and/or low oil pressure
Other than that, it's 1000000000x light years ahead of PowerFC
https://www.sau.com.au/forums/topic/181930-nistune/page/19/#findComment-7692083
Has engine protection ever actually "protected" a engine from failure though?
Referring to adaptronic/haltech and such.
My thoughts would be....it would be to late anyway...maybe it could stop "major" damage but at that point...you should know already lol
I guess it depends on the point of "failure"
Fyi, im at about 440hp atw with z32 afm
Pretty sure it can do over 500hp with a correct afm
Edited by jay-rod
https://www.sau.com.au/forums/topic/181930-nistune/page/19/#findComment-7692891
Yes. I have seen video of an RB30 with a Link cutting the power when the oil pressure gets too low and no, the car did not spin out and crash in a ball of fire.
https://www.sau.com.au/forums/topic/181930-nistune/page/19/#findComment-7692929
yeah ive seen many cases where engine protection has stopped or at lest reduced damage to engines.. if your paying top dollar for an ecu youve probably got alot of cash sunk into your engine too.. it wouldn't be used if it didn't work. theoretically
also my nistune has been flawless..even with the flex tune..definitely recommend
  • Like 1
https://www.sau.com.au/forums/topic/181930-nistune/page/19/#findComment-7696625
Whats the max hp the Nistune type 4 can handle. Is it suitable for a 30 25 neo with gtx3582r freddy plenum 1000cc injector hpx1 airflow meter.
Will it be up to the task
made over 600rwkw, airflow meter is the key, if you can measure the air your good to go. The new HPX in a 4" tube will go 1200 plus hp
https://www.sau.com.au/forums/topic/181930-nistune/page/19/#findComment-7699757
Would you be able to tell me how? Either through this thread or PM? I cannot find it in the settings.
Pretty much two options from my personal experience.
1. Set the AFM to Z32 and click on half value (if running 2) and adjust k value till your car hits stoich with o2 feedback disabled
2. Leave as is and adjust the k constant till you hit stoich on idle with the O2 feedback flag disabled
The beauty of the Nismo or Z32 etc. Is that the curve is nearly stock so there's no fancy calibration need like the HPX afm which I've yet to use.
https://www.sau.com.au/forums/topic/181930-nistune/page/19/#findComment-7703559
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
