How does everyone mount their rear plates? I just got my replacement plates and only just noticed that my rears have the sides bent to fit. No idea how I'm gonna get the new plates to bend like it is currently and I've heard cutting them are a no-no as well...
Ideas?
https://www.sau.com.au/forums/topic/181933-number-plate-mounting/
cutting is a defect as is having it bent, ive had a cop warn me over mine being bent.. theres just no other way tho.. cop was stumped as to what i should do, thus why he let me off with a warning.
As for if u do go ahead and bend it, pretty sure mine were just hit with a hammer to bend them lol
i had to cut mine to fit in the import garnish. Bending would have been worse on mine as it would have blocked the side mounted number plate lights. if you bend with a vice, remember to put a cloth or something over them so the reflective crap doesnt peel off on the sharp edges
I've heard that some imports have slots cut out of the rear bar so that you don't need to cut/bend the plates to fit, wonder how hard it would be to do. I know my bar is plastic so at least it'd be easy to cut. Anyone out there have slots? If so, how was it done?
I had an issue with my front plate. The car yard a bought it from fixed it by snipping the top two corners out. I thought that I could get defected so I contacted a friend who has a friend who is a Senior Sargeant in SA Police and he said as long as the plate is visible and the rego number is clearly visible and not defaced in any way then it is ok. So I don't know. I have driven past a few police cars now close enough for them to see my plate and they haven't stopped me.
You can make a decision on that I guess
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
