There is a 600hp ATI balancer, which is obviously cheaper than the 1000hp. I paid about $600 for my ATI 600hp balancer, as i do not intend to make more than 350rwkw on my car.
is that cutting it a bit fine? 350 x 1.34 = 469 rwhp. what drivetrain loss are you expecting? just curious because i'd have an ATI by now if it wasn't for the cost of the bigger one.
The ATI are obviously the better balancer but the new ROSS balancers are a very good unit. Especially for under $500 (unless of course it's a GTR). Even then you can use a GTR balancer, you just need to change to larger belts.
Things have come a long way in the performance industry in the last 2-3 years and even moreso in the last 12 months. Either balancer is going to see you safely through to 9k. I know of just as many people running ATI as ROSS and none have any complaints on either one. All are over 400rwhp, 2 over 600.
yeh sorry peeps... shoulda made it more clear.. it is for an rb26. to be honest i haven't priced either through my supplier, but have just done some internet research, and the ross ones seem to be atleast 300 cheaper then the ati. i don't intend to make 1000hp, i won't push it much further then 500@wheels.. and i know of plenty of cars still using the standard balancer at that power(if its good enough for 2BNVS to make 600rwhp, then it'll b ok for 500!). but... my engine didn't come with one.. so its just an excuse to buy a better one :) ATI seems to be the go, but if the ross is substantially cheaper i think i'll go with that. thanks for everyone's 2c. muchly appreciated
Edited by sic200
My rb30det will have a GT3076 hanging off the side. With all my performance parts, i am looking at anything between 300-330rwkw. The 600hp balancer is more than enough, and i wouldn't be surprised if the balancers are "underrated" to ensure a minimum of 600hp capacity.
Also i am sure that if people are able to run big HP figures using the std balancer, then even if i exceed over 600hp, the ATI balancer would still perform better than the factory one; Or would other problems (unknown to myself) occur ??
If i assume a 20% drivetain loss: (Is this too low an assumption?)
600hp x 0.73 = 438kw (at the crank)
438kw x 0.80 = 350.4rwkw
Yep same here...comparing ATI to Ross is like comparing a merc to a mini.
i thought you had a ross balancer? I guess you made the switch? which makes you well qualified to ask which is better! :)
ok... so next question.. if you have had an ross balancer and switched to a ati one... what difference's did you notice? ie. what comparison have you done to be able to say the ross balancer is cheese, and the ati one is the cheese? are there the 2 different types in the ross brand also? ie a 600hp version, and a 1000hp version? or just the one size fits all...
We sell plenty of ross and ati balancers at work.... for alot of RB26's!
You can't really compare Ross to Ati balancers, as said its like comparing a VS SS to a R32 GTR in track performance. The Ross and ATI balancers are both made for very different setups and applications.
Ati are and always will be a top end balancer, High punishment, long lasting and just made to a much better quality.
Ross balancers are great for minimal to medium amounts of abuse, random track days etc, but if you've spent considerable amounts of cash on your RB26 you shouldn't go past the ATI units, there not cheap but when you see the quality you understand!
Most of the High HP GTRS use the ATI Super Dampner 1000HP balancers... but the 600HP ones are great for track cars, drift and just plain tough street cars..
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
