Can some of you with autos please tell me what you've done - or recommend doing to get the most power out of them :)
I need ideas and inspiration not to mention im really curious as to what kind of power you are getting out of your autos :) hehe im sick of the manual guys teasing me - something needs to be done :)
Cheers
Lauren
https://www.sau.com.au/forums/topic/18330-auto-performance/
lauren,
to get more power is the same as a manual. Having said that you get slightly less power at the wheels with an auto as it chews a bit more power out of the driveline.
One of the good things a bout an auto is the fact that you can whack a high stall in them. Bad for your fuel economy but great for a mean launch. Most auto places can rebuild the torque converter in smaller diameter to increase the stall speed. Modified stock converters can yeild an extra 800rpm or so, whilst a custom unit can be set anywhere you like. I'm not sure what the auto's are like valve body wise but a good auto rebuilder can usually sharpen up the 1st to 2nd shift with a bit of a fiddle. Nothing like 'banging' into each gear and chirping the wheels.
On the stock turbo I'd say a 2800rpm stall would work very well. It would wipe alot of smiles off the manual boys faces very quickly.
I'm getting the volvo's turbo350 box rebuilt on wednesday with a mild stall and a valve body mod, I'll ask if they have done any jap stuff if you like.
https://www.sau.com.au/forums/topic/18330-auto-performance/#findComment-383177
i didnt put her on - didnt have the courage - didnt have $25 on me at the time haha i would rather not know - than know and be disappointed haha i will one day but for the time being she's just a stockie - running slightly higher than stock boost with a dodgy bleed valve - thats it.
Didnt realise u had an auto memphis! Have u put a cooler or anything in yours? An intercooler and replacing the horrible pussie zorst is my mission :D but i keep saving up for these goodies then having to spend the money on neccessities like tyres n shockies and now i need new brake pads *sigh*
https://www.sau.com.au/forums/topic/18330-auto-performance/#findComment-384793
Lauren,
You could ask chrisroi about his dyno run... 250ish RWHP, stock 94 Auto, with Full Zorst, POD, Front Mount, and 10psi.
His power anc fuel curves are close to perfect... I was amazed.
Dont forget when looking for a high-stall jobbie don't get one that's too high, or you'll be revving to 2000rpm before even moving...
That said, bully's Supra pulls 13.99 with only a POD and cold air, Stock zorst. His auto chirps into 2nd too!
https://www.sau.com.au/forums/topic/18330-auto-performance/#findComment-384804
JiMiH,
I think your confusing the shift kit with something like the B&M 'shifter'.
I have a B&M mega shifter in the volvo, it's a ratchet shifter for fast changes, however the trans being stock had other ideas about how quick it would change between gears.
The Shift kit is just a mod to the valve body to allow minimal slipage on gear selection. The most extreme case is banging into every gear, great for the strip but hell on the kids in the baby seats. You can have the change set to something inbetween.
https://www.sau.com.au/forums/topic/18330-auto-performance/#findComment-384973
hehe i would be happy with 250hp :P yeah my zorst is pitiful actually my whole car is pitiful - everyone elses cars came with toys but mine seems to be from the ground up job ;) hehe u got your zorst very cheap - they dont have a second one laying around anywhere do they :) haha
My ZX (also auto) just seems to make my skyline look like a slug ..... if i didnt have two flat tyres on it i wouldve put that on the dyno then my skyline cos the ZX's boost sends u almost thru the windscreen - boost on the Skyline is a lot more subtle. It irratates me that my old car is faster than my new toy!
https://www.sau.com.au/forums/topic/18330-auto-performance/#findComment-385408
oh sorry, when i say a larger stall, i mean a higher rpm stall converter :)
Sometimes u just cant get the exact car u want for the price nizmo, or u really need a car and hey theres a perfectly good one avaliable, just its an auto. Although economically it isn't really worth it in the long run.
https://www.sau.com.au/forums/topic/18330-auto-performance/#findComment-394687
Hey Nizmo
I have an auto too and the reason why I didn't buy a manual was because it was more expensive at the time, and I was short of cash and was just happy with a SKYLINE haha
Also I had bad experience with my last manual car, i basically lost 3rd gear and couldn't be bothered getting it fixed.
I too get heaps of SH$T from the guys because my car is auto, but hey at least I can drink my slurpee and cruise at the same time hehe. And half of them can't really drive anyway so I usually beat them off the line. But I guess if my auto goes hay-wire. I probaly install a manual gearbox.
Just one questions go the guys here, when doing a conversion from auto to manual to you have to change the computer as well?? The reason i ask was that one of my mates did a conversion a Vtec Prelude without changing the comp, and for some reason his vtec wasn't kicking in probaly.
I'm assuming it is because of the different gearing ratio and the extra gear.
https://www.sau.com.au/forums/topic/18330-auto-performance/#findComment-395197
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
