  • Replies 682
Jeez Paul, that seemed effortless!
Sounds horn too!
yeah was a pretty easy pass...1st one with everything in order. Clutch was used in all shifts...time to turn the boost up, tweak the suspension settings and stop using the clutch.
  • 1 month later...
what mods have u made paul? bigger turbo HAHA
nothing yet...arrive back in qld on monday and ill start sorting a few things out that should see some good gains. Nothing crazy the set-up will be pretty much the same as i believe now all the car needs is a few tweaks...we are going to try a few things in regards to fuel, boost control and suspension.
  • 1 month later...
Righteo...just a quick update...new fuel system and wheel speed based boost control system installed. Mark will be back from the states tomm. so it will be on the dyno very soon for tuning.
Ive entered the Aust vs USA Nitro funny car 2 event series on the 2nd and 16th of January at Willowbank. They have grouped Super Compact with Competition Eliminator bracket and have me racing dragsters and doorslammers. I have resigned myself to be swiftly knocked out of the 1st round of eliminations as my index for my class (Super Compact AA/SM) is 8.38. Should be good fun racing against some big cars running 6's and 7's.
Edited by DiRTgarage
time to get the slicks out and make use of that little blue bottle?
slicks and NOS have no place on a street car :P . It will be fun getting smashed by Austraila's best. The sound of a low 6 second doorslammer passing me at the 330ft mark may leave a nasty stain in my racesuit though :) .
slicks and NOS have no place on a street car :woot: . It will be fun getting smashed by Austraila's best. The sound of a low 6 second doorslammer passing me at the 330ft mark may leave a nasty stain in my racesuit though :) .
How oftren do you actually drive it on the street (serious question)?
whenever i feel like scaring myself...its mental on the Toyo road rubber...low boost and 1/2 throttle is all you can really give it without becoming part of the scenery. Since the car has been based in qld i haven't had much of a chance to go cruising in it...but once it goes back home it will be taken for a road run whenever i get time.
The car is reasonably well kitted out for road duties as only the rear trims and seat have been removed. It still retains all factory front trims and controls. Even the front and under car sound deadening remains and all the glass is factory as well as power windows. Its pretty much all there except the rear trims and seats as previously mentioned, the air con and the stereo.
Its road registered, runs plates, its a full bodied car, is only marginally lighter than a standard car, runs street radials and doesn't use nitrous. It was fully legal to run as a street car in the ANDRA sport compact drag series, the rules were fairly strict and even stated you couldn't remove the roof lining or carpet.
Ben Bray 3000hp 2700lb Top Doorslammer vs Paul Diemar 1000hp 3400lb Street GTR
Its going to be a massacre!!
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
