That's fine Shane, hope you can get her back on the road soon.
** PM's have been sent out to all entrants regarding the pre-meet this Sunday **
For those who are interested on the Friday cruise but not entering SCS you won't be able to enter the meeting point but, ya can join in once the cruise is underway. I don't know the precise meeting point till we receive the entrant pack in todays or tomorrows mail.
  • Replies 187
Thanks for the PM PK.
I Failed Regency today.
No biggy. Will have my car back on friday and through regency hopefully.
Then up on a hoist friday night/ saturday putting everything back on for Sunday.
So no cruise for me on Friday night.
Sorry about letting the team down guys.
And im loving this event being like around the corner form my place HAHAHAHAH
ah damn u failed! :) What for?
Never mind bout the cruise, the main event is sunday, so glad you are still in for that! Yeh im loving that its like less than 10 mins from my house to the event :P:D
HAHAHAH flick, Try about 1min.
HEHEHEHEHE OH the wonders.
Trust me, my car will be very clean, very low and very HOT.
Well hoping all goes to plan.
MOOOOHAHAHAHAHAHAH
Looking forward to sunday and showing SA what i have made my car into.
Hi
Can somebody pm or email me with the friday cruise details.
I will not entering the show but I am just wondering if I can cruise around with u guys or not(have to work in city at that night, finish around 9:30pm).
I may ask some of my frds with their skyline too.
Thank you
Benny
Hey all,
Will not be on the criuse on friday night but will be there on sunday as i detailed the car last night and really do not feel like doing it again on sat ready for sunday. Plus i have all the club gear in my boot for sunday and dont feel like cruising around with it in the boot.
See you all on sunday for a great day.
Shaun
Yeah won't be on the cruise friday either.. got work drinks that night... so i'll be there on sunday morning. I'll remember to bring the tent/shade with me.
What's the forecast that day?
Friday Fine. Mostly sunny. Min 13 Max 27
Saturday High cloud increasing. Min 15 Max 28
Sunday Fine. Partly cloudy. Min 17 Max 26
Monday Fine. Partly cloudy. Min 14 Max 24
Tuesday Fine. Mostly sunny. Min 13 Max 26
Wednesday Fine. Mostly sunny. Min 17 Max 29
Also would like to say good luck to everyone going in SCS, hope you all have a ball!
Im off to Fiji on Monday to get married!! WOOOOOOOOO
Way to go Lee! Have a great one in Fiji buddy.. and wish you all the marital bliss in the world. Shirl and I got married middle of this year too.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
