Spotted a Caterham Fireblad on the way to work! I don't think I've ever seen a real Caterham on the road before!
Oh also spotted a 370Z... was pretty meh, not different enough to the 350
You can register Caterhams? :(
Awesome..
gotta get me one lol.
Actually come to think of it..that would explain why i thought there was one at Blacktown Tafe one night..it had a car cover on it..but it had that sort of shape
  • 3 weeks later...
Spotted a blue Ferrari F430 Scuderia, Miller St Cammeray.
Also has the number plate '348' which itself would be worth about 5 times my car.
Also nearby were a black Maserati GranTurismo and red Quattroporte, looked like there was a Mafia boss meeting at Maggio's cafe...
You can register Caterhams? :/
Awesome..
I don't see why not... You can register a PRB which is a caterham copy, but I had never seen a real caterham on the road before... my boss used to race the PRBs, they're crazy quick! Beat the race porches... Dog box and semi slicks on like 155 tyres were a bit shit on the road though :domokun:
  • 2 months later...
Not only am I bringing this thread back from the dead :P
but I also spotted a new black Porsche 911 or 997 turbo wedged under a bus next to a sideways standing bright red new Commodore at the offramp in Chatswood. Looked quite bad, and seemed to delay traffic a fair bit too.
Saw the owners standing on the median strip taking 'not-so' happy snaps
  • 1 month later...
my evo +2 maseratti's.
The red spyder is gay....
the 3200gt is pure sex, silver is a better colour for it than that green, but i like his cream leather colour, mines a navy blue, makes it look old
sixty seconds after I took this pic, it was gone
(sorry)
I don;t remember gone in 60 seconds too well, but didn't elenore have a different rear end?
I spotted a Maserati GT convertible last night on the Central Coast highway while I was on the way to the regular Coastie meet-up, and this afternoon I spotted an Aston Martin fuelling up at Caltex on the corner of Powers and Station Roads in Seven Hills.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
