hey all. I have to pull off the balancer from my RB30 bottom end and it is just a short motor. I rung an engine reconditioning place and they told me how they do it and I am not really keen on doing it till someone else says it will be OK.
they said a rattle gun will not have enough torque so forget that.
they told me to remove the sump and wedge a bit of wood between the crank and block then get a HUGE breaker bar on the balancer nut and apply a lot of force.
Will this possibly damage the crank? last thing I want is a bent crank...
sorry for the newb question :)
otherwise has anyone else got any ideas on how to remove the balancer from a short motor not installed in a car?
Hi CEF11E,
This is how i have done it before, and it doesnt damage the crank thats why you need to use wood as its softer than the crank so wont damage it.
I used a 3 foot breaker bar when i undid mine and it stil ltook alot of effort, and even then i needed to use a gear puller to remove it from the crank shaft.
hope this helps you
cheers
depends on how good your rattle gun is and air supply...
You should be able to do it with a normal breaker bar with 32mm socket i think from memory, if flywheel is on, use a screwdriver between teeth and the dowel on the block for the gbox. If no flywheel, put two bolts into the flywheel holes and put screwdriver between those two to hold the crank from turning while someone else undoes the crank bolt.
Then a puller to get the balancer off the crank.
27mm from memory.
the 'piece of wood between the crank and block' trick works well.
you arent wedging it on the main part of the crank, you're wedging it between the big counter-weights, and they are pretty meaty. you will not do any damage to it at all.
if u needed to remove the balancer with the motor in the car could you put the car in gear with handbrake on or will this damage gearbox?
to remove the bolt, get a breaker bar and have it lean over to the left hand side of the motor (right hand side if you're looking into your engine bay) so that it is levering on the ground.
then just crank the car and it will undo the bolt.
Yes, I believe that you are supposed to leave it in gear to undo it; alot easier this way too!
May get away with it this way with an rb30 balancer - I doubt it though as it will just slip the clutch. You can also remove the starter motor and jam the flywheel or drill a small hole through the bottom of the bellhousing and jam it that way.
lol you'd go to all of that trouble on a short motor when you could simple jam a block of wood in the crank somewhere?
Its seriously not that tight.
You just need a big breaker bar. :blink:
You just need a big breaker bar. :P
With a 1m piece of steel tube as an extension.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
