Hi everyone:
As permoise, I am writing a instruction for DIY A/V input for 350GT without reverse camera.
Please note: If your car has a reverse camera, this instruction not suit for you. Please ask Chris for help.
Edited by Frank350GT
To begin with, All the setup is based on these pictures:
As we can see from picutre,
The TV unit is actually reserve a empty input socket (White one) for future extension.
In the factory setting, this dock is used for reverse camera, but afer that Russian guy have a look at the board also IT DOC's practice, We can do something
On that.
These are meterial I purchased from dick smith. total $14.xx.
sorry for the picture from DSE website, I forgot to picure them.
I have to purchase audio and video seperatly as DSE do not have them in one piece. : (
4m flat 4 core shield cable, $2.29/m
RCA Socket - Gold Series , $2.89
Skt RCA Bulkhead Mount YELLOW $0.58
12 pin Locking Pin and Plug Header $1.98
nice writeup.
so when you gonna post the final results!!i wanna see the quality you get on the screen.
is it composite or component (rgb) video i cant tell ?
Edited by cookie--monster
not bad :)
hopefully I'll know more about this plug over the next few days and we can tidy it up a bit.
Edited by Chris Rogers
not bad ;)
that is fantastic, You know, i am really not good at those stuff, only the plug cost me almost 2 hours.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
