im lookin to get a whole new ecu not a piggy back does anyone know a good one that works well ? some were saying the autronic motec and haltec but dont they have problems with the traction control
correction to my website...
www.drdrift.com.au
Full ECU is possible, with real time tuning of fuel and ignition mapping, injector and AFM upgrades, speed cut and boost cut modification etc are no problems.
Sam.
  • 4 weeks later...
just bought a Emanage Ultimate for my R34 auto and am having problems with the tuning. there is a drop in the power and then kicks back up, some thought it may be the auto converter but its fine any ideas ??
Could be detonation from a bad tune going onto the safety map, could be the fact it's going to the rich/retard area of the factory map, and the e-manage cannot compensate enough? More than happy to have a look for you, with a combination of nissan consult and e-manage and dyno I'm sure we can figure it out...
Sam.
Sam.
i will get it sorted, i have spoken to your tuner and we have sent the datalog off to the jap engineer for him to diagnose. i am to busy atm to personaaly look at it but im sure the greddy guys will have it sorted in a heartbeat if they dont i will try make the time to have a look.
  • 4 weeks later...
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
