  • Replies 68
well I figure since you drive it hard the dogbox is probably the smart choice for you. should be good fun when it's set up with the ign cut shift too. :P
i wish i was "allowed" to get one too...
ive got an Autronic SM4 with ignition cut shift too, coupled with a straight cut dog box would be heaven.
life is so unfair....or should that be "wife" is so unfair?
Disclaimer: although the above post was made on this account, it is not necessarily Paul that wrote it. Just incase Stacey is reading it.
what problems did you have with the ppg? and what bits needed replacing? did you have an ignition cut on the ecu for gearchanges? and did you use the clutch with it?
once this gearbox is in. it will be 70/30 track/street. thats what lary the laser is for :(
I broke 2 small input shafts, lay shaft bearing and need to replace 2nd gear. No ignition cut. I always double clutch on downshift on the race track and during slow driving around the street
Hey Guys still trying to get used to the box, just a qwuick question. When your just driving around normally(not on the track) do you find that you have to shift slowly and in 2 stages rather than just trying to smash it in like you would when flat out??
As it seems to be wearing in it is becoming a little harder to use around town.
Cheers guys talk soon
Matty
I found the same thing. The delay from shifting in 2 stages allows the gears speeds to match. I find double clutching on upshift (and down shift as well) on the street doesn't produce any noise what so ever during shift.....very gentle and graceful. Flat out driving there is only one joyful way of doing it as R33 racer stated. However I still have occasional trouble with 1-->2nd and often use the clutch for this. Does anyone have any special trick with 1-->2nd?
cool. yeah i would be getting the larger input shaft option. and all brand new bearings. and also will be making a spraybar for inside the gearbox to directly spray oil on each gear. havent quite got it started yet. either using a pump of the tailshaft or an eletric one.
do the straight cut gears suffer from lubrication issues in the gtr casing?
matty
when we are just chugging around, i have found being really forceful with the change is best. If i just lazily put it into gear in most cases it will chatter on the dog gears and feel rather harsh. best to be acertive with it even at slow speeds.
cheers russ cya soon , congrats again mate on the pittsworth win!!
Cheers guys was a good weekend. Yeah i suppose experience with it is the only way to figure it out properly. Im finding that when im just "chugging around" and try changing forcefully it jars my wrist every time as it seems to jump before it engages. How long did it take you to get it into 3rd 1st time everytime?? I keep seeming to either get 1st or 5th lol.
Cheers
Talk soon
Something else to watch out for is oil being pumped out the breather. I run straight cut ppg with redline light weight shock proof oil and i have problems with the oil coming out the breather. Does anyone else have the same problem with there box? I added a longer hose and run it up into the engine bay to the highest point not the best solution but it has stoped losing oil. I think i might have to pull the box down and install a shield where the breather pipe is.
with the breathing thing I know john runs on both diff and gearbox basically an expansion tank. so he runs the breather up to a small tank which is ventilated. the GB oil can be thrown up into this little tank, then drain back into the box. basically just like the radiator expansion tank. seems like a good, simple idea. could be worth a go.
33 racer which oil do you use? If the breather problem can be solved down in the gearbox instead of further up in the pipe we can have a breather that will do what it designed for... What i thinks happening in my box is the light weight shock proof is very sticky and the gears are flicking it up onto the roof of the gearbox then with slight pressure the box create it pushes it up the pipe. Now im not sure if we have enough room above the gears to install something like a baffle to deflet some of the oil away from the breather. Does anyone have a box thats in pieces at the moment to check out if this is possible?
were using the shock proof light i think it is, the blue one which ppg recommended for the box.
We dont have a box in pieces unfortunately, however i reckon the mini catch can with drain back would work well for it.
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
