  • Replies 68
has anyone read the temp the oil gets up to? my boss (used to be the x-trac guy in aus) says the straight cut gears heat it up alot..
also ive got the box in,(straight cut) man it was a hard week of learning how to shift at low rpm :P but ive got it pretty well down. basicly having a pause between each up shift then quickly engaging it. and rev matching on down shifts.( almost broke my hand a few times when my concentration slipped)
no thud or bauking. :wub: but having the standard tailshaft and a relativly heave os r3c clutch doesnt help... il e getting a 1 piece molly one from uas i think, as mines got heaps of play in the joints and damn its loud when changing fast at low revs :/ a big ting/thud can be had if the revs dont match.
but one thing i found is my hand can go faster then my feet. so perfecting changes is still abit off yet lol.
sorry to hijack this thread, but as it seems there are a few people here who use the PPG dog box i thought i might throw up some Q's
We have finally broken the little old stock RB25 box and am upgrading the gearset..... car makes about 450rwkw and is predominantly street driven, about 5000klms a year. Other than that it gets drag raced with ET Streets and a gearbox breaking 2 step :) What would people suggest???
Was looking at the helical dog box, this is the quietest option, but am now a little concerned about wear on the dogs. Given i cant get the box out without removing the engine i dont really want to be taking the box out every couple of years just to repair/replace dogs. I am not really a synchro abuser so would the helical synchro box stand up to about flywheel 800hp????
Any suggestions??? pros, cons etc
yeah, if this one i got didnt pop up i would of gone helical and synchro. after a week of learning it ive got it 90% down. but.. you can change gear faster at normal cruising speeds with the synchro one. ie. 2000-4500rpm. (most street revs)
one thing i found with the dog box is that at low revs you have to rev match it or its just a nasty hand jarring experiance. and not to mension hard on the diff/tailshaft.
so cruising around is a chore. have to revmatch it and take time on upshifts. so basicly rev match it or change at 8 grand if you want it nice.
but 1st to 2nd is a nasty change. no matter how hard and fast i jam it in it atill doesnt feel as nice as 3rd.4th,and 5th. anyone else have this issue? and is it because the 2nd gear has more dogs and is bigger?
oh, and while i was inspecting the gearbox, the bolt for the 5th shift fork was loose :s and i made a spacer for the 5th gear bearing. so if the circlip moves the gear wont :) is that what you meant russ?
top job mate, thats exactly what i meant!
cheers russ
We had the same issue with a GTR we prepare and Terry from Award diffs said soemthing about the clutch being partly to blame for second gear crunches..... have a talk to Award Diffs or PPG direct as they can probably give you the fix for it.
I am still undecided though..... the box ixnt out so there is plenty of time to decide
Given the car still retains its full interior and runs on PULP i would be very very happy with 9's Paul :thumbsup::)
At the end of the day i think the righ option is the straight cut PPG dog box, but i dont think i can live with the noise..... they are so damned loud!!!!
i used my PPG for the drangs on my super built engine with a autronic SM4. but that damn thng is too hard to drive on the street. i drove the car once with the full race setup to work and back. on the way to there it was hell, with flat 10k changes but on the way back i hit traffic on the highway, nearly bored myself to death. once home i got to removing the box and putting my OS gearbox with my 450 kw engine back in, cuz the car is bloody bad to drive with that thing in on the street, it is a monster on the track though
  • 1 month later...
Well, I love my helical gear set in my GTR. I have no problem driving it fast or slow, you just need to learn HOW TO DRIVE!!! Hell my girlfriend can drive it around town without banging and crashing the gearset. I do however love the solid thump when it goes into 1st. he he he. My GTR runs mid 10's in street trim, 400rwkw with T517's and an R3C.
Well I waited 6 weeks to drive my car while I waited for my PPG Helical dog gearset....and I lasted two hours before accidently shifting from 2nd to 1st instead of third. Blew a diff :banana:
It took about an hour before I wasn't crunching gears, and I didn't use the clutch on a power run from 1st to 4th and it was like a motorbike. It's unreal!
Just be careful that you don't go back into third, because unlike a syncro box, nothing really stops it from going in!
SPEWING!!!
Does anyone have a GTS-4 crown and pinion for sale 4.375??? Help a brother out!
Edited by PJ.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
