  • Replies 90
Surely a sign of inexperience.
I don't know him but im guessing he has never been to WSID before in his life (no idea where the water/burnout is, no idea where to stage and no idea how sticky the track is), has just recently bought the car and decided to show his mates what the car is capable of. Unfortunately the concrete barrier showed him who is boss and he didn't get a time card for it...
hey people im off to WSID in my skyline for the first time......
so i dont know how i will feel on the stage.. hope i dont make a foool out of my like like that Dhead.
but still i wont be that dumb....
who will be there next week.........
me...ill be at the gate all day waiting...come early and join my picnic...hehe
coool ......................i guess ill see you there..
i will both my cars there
i will have mt sexy R33 gtst S2.........it will my turner add on the back which is TEAMK KUSTOMS
and i will also my baby the nissan pulsr SSS N15
so yeah dont be afraid to say hi yeah
I think he thought the answer to his problem was give it a little more throttle to send it the other way.. and a bit more.. and some more and now you've dug yourself a big hole, not only are you out of control but you're moving faster than you were before when you started losing control.
I learnt that the hard way lol :blink:
I can't believe you guys are all so harsh calling him a dickhead etc. I feel sorry for the guy. sure he couldn't drive but he was just having a go. he made a mistake, lost control and pretty much wrote off his car.
I agree 100%
yes it is a shame. man it was spectacular to watch. im asuming he asumed the 4wd will straighten it out. so his foot was burried the whole time!! well till it was past the point of no return anyway.
nice looking gtr aswell :wub: lesson learned.
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
