  • Replies 66
i have a gt-k 500 for my s15, im in the same boat as u are, yet to even put motor into car....
these turbos are supposed to spool up a minimum of 30% earlier that a garrett turbo that is 1 size bigger.... and turbonetics underrate thier turbos....
the gt-k850 you have there is rated to a minimum of 850 horsepower....
the dudes in the states recon that my engine setup on the sr20 will make 480hp at the wheels quite easily on aussie pump fuel..... abit crazy in a s15 but i love it... :mellow:
what power you aiming for???
Edited by den001
There's not really a power aim anymore! i was literally about to purchase an HKS TO4z kit, when i was told these were just about to come out. before i was aiming for around 460rwkw with the TO4z based on others' results. Apparently the GTK will push out more power with similar response to the TO4z, well at least thats the idea, its certainly rated higher. I think the GTK850 is like a T51R KAI, but with a 0.8 ex housing so should be decent response. Id be more than happy if we could see 800hp at the engine, but with a 0.8ex housing, i wouldnt bet on it, on race fuel maybe, but on pump, we will see.
rb26s13, you wont have to wait till its in the car to see results :) Its getting run-in then tuned on an engine dyno, so i will have a true "at the engine" HP figure. Im waiting on my Nismo plenum from greenline, then wiring up the motec. Once the plenum has arrived, if the workshop isnt flat out shouldnt be too far off.
cheers!
Yeah i figured the engine dyno run in would be pretty safe, plus i want to know as close as possible the actual engine output, without having to convert back from the wheels. Any one else done this on a new motor?
The Nismo plenum's in the mail, but have been discussing a single throttle plenum with my engine builder..
seems to be a large range, from under a grand for a greddy plenum, up to 3grand plus for a Jun. You get people swearing by a single throttle setup with a big single turbo, but then you get those showing big HP figures running a STOCK plenum.. So its a bit confusing. I recall Sydneykid telling me that with a MAP sensor based ECU such as what ill be using, that a single throttle will be much easier to tune.
Im just wondering if theres gonna be much of a trade off, 6throttle vs single throttle response wise? End of the day, the things built for power, so a single throttle makes sense. But its also more money, considering ive already bought the nismo plenum :mellow:
looks amazing bud :laugh:
hypertune now make a 6 throttle plenum, but theres no way in hell im paying the ~2.2k for a plenum :P
plus, the std's been shown to cater for big hp cars, just requires some fine tuning of the rear 3 injectors
P.S whats the pricing on them turbo's like?
  • 9 months later...
hi guys,
yet some more final touches... blk180 youre right, the hypertune plenum was the way to go!
heres from last time
and today... the cam covers were colour matched to the turbonetics compressor housing. For some reason the camera flash makes the dark metallic paint on the turbo look whitish grey in the pics, but in real life its exactly the same as the cam covers appear below, nice.
and now i await the dyno...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
