  • Replies 56
OK, Just saw the IPS Driver Errors just now.
It looks like the service which keeps the search index up to date is causing table locking on the posts table. I have been meaning to convert that table to Innodb (no table-level locking) but haven't gotten around to it. I'll try to do it over the weekend.
from what ive seen so far and learnt it seems the actual database is probably the bottleneck
300-400ms isnt exactly crash hot but that certainly wont make the page load in 20 seconds plus
typical loading times i am seeing from a few sources is well into the 10 seconds for a page load
it could be a case some users have some stupid indexes or some whacko foreign keys etc on them
my access is pathetic, it takes 10 seconds + for any thread to load
if i fork more connections its not different they all just take as long
its probably a case we are maxing out mysql and its not perfomring as well as it could be
a load average of the box is exactly that, the average load in the running queue
it does not give an accurate representation to how mysql is performing if it has 3 childs that are running as the load will just show around 1,2,3 etc
but if each of those pids is fightint for locking resouces (which mysql is HOPELESS at) and other resources then yeah its going to suck
how is the database setup, is it on localhost
has anyone optimized the schemea?
has anyone looked at the slow queruies (theres a command arg to log them)
how are the indexes setup for the big tables?
if you do show process do you see much locking processes or waiting?
wht about copy to tmp_table do you see much of this?
the actual tcp response from the box is a bit slow which is probably due to system load and number of apache childs
they could be fighting for resources, competing with other junk or it could just be the box is busy
a good test is;
open a dos prompt
telnet www.skylinesaustralia.com 80
then note how long the socket takes to open
this is a good sign that it could be either network or server/httpd process contention
then once its open paste in;
GET /forums/style_images/1/bc_new.gif HTTP/1.0
HOST: www.skylinesaustralia.com
and hit enter twice
it should come out pretty quickly and then end
so if it does then it shows the server and your connectivity is pretty fast
i think its only when you load the main forum pages that it takes ages
which is probanly all the sql seleciting and other junk involved
can we move to another datbase other than mysql?
postgres would be so much better
not tryring to be a know it all and pointing blame etc
more interested in getting it sorted
there are lots of tools to help debug slow pages / database etc
apache_top is a good one
the mysql slow_process command line is a good one
without the proper access i can only speculate and guess
but i know its driving me nuts and probably others
do we need to donate some more $$$?
Wow Paul, great post! Its good to see people taking an interest in fixing it rather than just getting cranky!
I agree wholeheartedly with you that it is MySQL. I have been playing with the conf for a few weeks now, I just cant seem to get it to a happy medium between load and speed.
Re. your questions;
- Yes
- Its the default IPB Schema with additional tables for mods / hacks and other things
- Yep, I log all slow (>5 sec) queries to a slow query log. I just havent check it in a while).
- Not sure, but I have checked the indexes through the admin cp of IPB and it reports no problems.
- Only occasionally. I have been considering changing the posts table to Innodb as we dont use full text on it anymore anyway as search is taken care of by Sphinx
- Hmmm, havent noticed.
Also, I havent analyzed the database for a while, thats definately worthwhile doing.
I have a few ideas for speeding the site up. Postgres wasn't one of them but I am more than happy to go down that path. I was also going to setup lighttpd to serve static content (images mainly) and have apache looking after the php side of things.
You sound like you know your stuff, I'll be more than happy to give you access to the box to have a poke around if you'd like?
Thanks Paul,
Christian
hey no problems
happy to help out
the big ones that are likely to yield help will be chcking out apache_top
and looking at the mysql process listing it
it could either be httpd contention, if it is then its just apache conf tweaking
and if its sql related then we should find it in show processlist and other mysql checks etc
it cant hurt to manually check the indexes and the database shouldnt need to be 'checked' as in check table
as that will look for corrupted blocks etc
postgres will only help (or another database) in the event that mysql is bottlenecking
that is, its bottlenecking due to the way it locks the tables
mysql cant do row locking as its too simplistic so when someone makes a changes to their permissions
or adds a new thread etc it must lock the whole table and commit that change
so for the time being while its locked nothing else can read from that table
so you have all the other processes waiting for 'waiting - locked table'
ive seen it all too often with mysql and high performance based websites
postgres, sql server, oracle etc all do row locking
in the sense when a row is being updated or inserted they lock that specific row only
and allow access to all the other rows so your application isn't any wiser
im happy for some access to have a look around and see what i can find
maybe its something easy or maybe its something complicated
cant hurt to loook
hi guys
sorry about the late reply.
well done. The site is definatly faster from home and work.
Its still a little slow, but a hell of a lot better than what it was.
A little bit more tweaking and it will be perfect!
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
