  • Replies 63
get a friend to sit in the passenger seat while you're at 260 and stick bits of paper everywhere till it stops...if that doesn't work, jerk the wheel to the left 90degrees and it should get the parts behind the dash to settle into their factory positions...
hey, i've noticed that once im going over about 260 there is a really weird rattle that for all I can tell seems to be coming from the airconditioning vents. Is this normal, or should i be concerned?
To fix this; stop car put it in neutral and put a brick on the accelerator so that it stays to the floor (ensure rev limiter is removed) then leave it like that for bout 1hr, should sort it out! To fix it even better take to your intercooler and exhaust with a hammer first to inhibit air flow, its good for rattles!!
Goodluck
Edited by r32line
lol . May i ask what your tacho is at when at 260km/h.
My R33GTS-T is limited to 180km/h and thats doing about 5000rpm in 5th gear.
it shouldnt be reveing that hard im sure mine doesnt
mine cuts out at 6500rpm in 5th , it like a second speed cut dunno what speed its doin bout its way off the clock somewhere , i have the speed cut on a switch mine sodest rattle at all at this speed been told by a commodore drive it was about 250?
I find my penis enlarges every time i brag about high speed on a public forum...
and ive done ALOOOOOOOOOT of bragging* :thumbsup:
*may or may not be true.. please consult a doctor if symptoms persist
Edited by MotoMan
hey went for a drive this morning, and your right jutstar my r33 does bout 4800rpm at 180k
Does any one know what the second speed cut or what ever it is that stops ya goin faster?????????
:) I thought you were going to lock it?
The speed cut thing usually goes in slightly after 180km if at all as far as I know.
More like the speedo's are ambitious at best at that end of the scale.
Why lock a thread as excellent as this?
yeah i was running some stockies off a ba falcon not sure what size they were , pretty tall though think they were 225-65-or 75 r16 or something it took a while to get the last 50k in 5th though, so does any one know whats the second cut is? its not the rev limmter.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
