  • Replies 82
JAGR33 runs the Alcon kit. He bought the front set and loves them, a few months later he bought the rears as well.... He has close to your power as well....
Also as SK would say - increase corner speed then you don't need to brake as much :)
These ones?
Sure they are 4 pot Alcons but Greddy/Trust have never released those Alcons under the Grex banner. The ones you have attached are the latest Monobloc which to the best of my understanding are only available through Alcon and not contract manufactured for anyone else.
Attached is the Alcon caliper that is contract manufactured for GREX. Typically the kits use 330x32mm rotors. My mates S14 used to run them and they are a very nice caliper. Slightly more comapct then the F50s etc as well, though they dont run as big a piston either which is probably why they are better stuited to the slighly smaller rotors that most GTR guys like to run :thumbsup:
They are quite a nice caliper and relatively cheap these days. you can buy them new for about $1750-1800. I almost bought them instead of the F50s i have, but i wanted to run a larger then 330mm rotor....i ended up grabbing the F40s simply because these run the slightly larger pistons and can are perfect for the 343mm rotors that i have.
Starting to regret not spending the extra $200 over the F50s and getting the 6 pot Alcons...lol so many brake setups sitting around my house...today i want understaded std GTR Brembo loooking calipers, tommorrow i want scream at me i have big brakes :P
Alcon_Type_B.pdf
I saw those. So tempted to buy them , only i think the price of pads would be about half what you pay for the calipers. Also i doubt there would be anything but competition pads readily available for them...and then because they are 30mm thk pads would take forever to warm up. But they are oh so awesome looking calipers :D
Maccattack - I have the Alcon kit front and rear, awesome stopping power with no fade whatsoever.. I also run the Nismo brake ducts...
Highly recommend it....
I'm actually quite surprised your getting more than 2 laps with the power output of your car.... Scotsman on these forums has around 340rwkw with standard Brembo calipers DBA 5000 rotors and the brakes are cactus after 2 hot laps at Sandown...
Jack,
If you don't mind asking - how much did you pay for the full kit??
I have been quoted about $5k for the fronts alone.
I bought mine through Unique Autosports, was about $8.4k for the whole kit, so 5k for the fronts sounds about right...
Check here: http://www.nismo.com.au/pricelists/pricelist_gtrbrakes.htm
Although the kit comes with Ferodo DS2500 pads for the front, if you ask nicely I'm sure John at UAS will chuck in the Ferodo DS3000's instead....
DS2500 are good for the street, but with your car you'll need the DS3000's....
And here's a pic of the brake kit on the car...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
