Hi All, i am very interested in these M35.
Regarding the 4X4 system does any one no much about the distribution of power?
Is it like the older GTR systems full rear then spread to front when rear slips?
Are there aftermarket bias controllers available?
Regarding parts and so on what kind of costs are there? EG Auto failure Big Stuff and little stuff brake pads what fits.
The Big Question: Insurance? are there any 26 year olds on sau that have one of these fully insured? What does it roughly cost ?
Any futher info would be greatly appreciated
Pikie
The 4x4 system is rear biased but upon slips allocates upto 45% (from memory) to the front. On the ARX it has a limited slip rear diff as standard. The ARX also has 2 syncro modes for starting on gravel or snow. This allocates some power to the front up to certain speed then it goes back to rear bias and power to front on slippage.
Have a look at the link, http://www.nissan.co.jp/STAGEA/M35/0110/, there are demonstrations of various functions including the 4WD function and the modes.
I insured through Just Car as Shannon's would not insure me without a garage in NSW.
Andy
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3536578
Hello,
I recently got my car insured by Famous Insurance ( Ex Vigil), previously they did not do M35 Stagea's, but after some discussions with their underwriters they now do them. I got a good quote for my Stagea AXIS. Under $1200 for a rating 1, over 30 on the Northern Beaches of Sydney.
If you need more details PM me.
Jules
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3552962
Hello, Just some pics I saw on the net about the Blitz FMIC for the M35 Stagea.
For those interested. But would it provide any decent benefit....thoughts anyone.....
Edited by Paramour
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3580461
Ahhhh....looks like a good setup for the intercooler.
P.S. Like what they have done with the mesh over the inspection port on the cold air box....must get the mesh and do that myself.....saves buying a POD filter and produce's the same result.
P.S.S Also got a quote on doing the turbo up yesterday....not cheap...$1,200 for the highflow and new impeller.....good for 13PSI everyday though....must do!!!....must get more HP.....lol
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3582049
Have you seen the airbox of a V35? They have a piece fitted to the front of the airbox that works to have it open like that and only get cold air!
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3582119
sounds a lot cheaper than mine even with exchange rate and 12.5% gst factored in but I prob paid the mechanic's markup as well
I notice it feels stronger but there's more lag
can't tell you about hp as I haven't dyno'd it yet
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3582180
You got pic's of it?
Anyway thought I might post this here as well....its a pic in English of the DVD/TV/SatNav unit.....now we just have to sorce the button's.
Have a look at the intake on the far right of the picture.
Let me know if you can source the buttons? Do you have any contacts in the US?
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3582499
What we really need is the English version of the software so we can read the screens!
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3582503
Thanks for all the information, I am very interested in getting one of these M35's.
Quick question tho: I am trying to work out how what model gets the 3 gauges in the center console unit? from looking at the pictures I think they are turbo pressure, oil temp and maybe volts?? Obviously i would like to get a car with this as an option.
Or, does the TV screen display any engine management at all?
Cheers.
Also, has any one registed one of these in south australia? will I have any problems if I buy from interstate and register here?
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3593242
I am pretty sure that it's the 2002 - 2003 Nissan Stagea 25T FOUR-V 4WD turbo your looking for. As for the TV screen....next to no info is on this....infact it's pretty useless until you convert it for TV/SatNav/DVD. The TV does display however your direction and fuel/travel info....plus some other shit of which I have no idea....need a translater...lol.
As for rego, I'm no expert but once it's complied you should be able to register it in any state(check with you dealer/compliance first).
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3593271
having just got back from a trip up north I will say that this 250T RS four is an awesome touring wagon and will not disappoint
has tonnes of torque right where you need it and the awd comes into its own on those steep metalled surfaces where traction becomes an issue and in the wet, the tail-end of cyclone funa having crossed my path
I would like the ar-x if only for the fact that I like to venture over rougher ground where clearance is necessary
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3595694
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
