I an really trying to like the M35, but that arse end is so ugly. If someone was to make adecent rear lights kit, like was done for Commonwhores, I may be tempted. Front and side, AOK, but...........
I have bBenny,s pic as my desktop.
Actually, if you have a decent looking rear muffler and drop the car ~25mm.... the rear can look alright.
If you don't like the Volvo lights, just get a reflector cover kit (Yahoo Auctions/Import Monster) or take the whole light of and paint it yourself.
Here is a 2002 Axis with top reflector covers
And here is the Pond M35 rear... rear bumper and full reflector cover kit.
Nissan made the arse end like that just to keep the cops off my back. Works a treat, even with a 3 inch straight through exhaust.
Just gotta get some Volvo badges for the back and I will be in the clear.
You could always paint the top part of the lights to match the car...
;) .... for now
I've noticed that a lot (possibly all?) M35's have the stereo controls moulded into the centre console set up as opposed to the old swappable DIN system.
I'm assuming the radio frequency range still cuts out too low on the FM band like other imports.
What are the options for replacing the stereo?
What do most people do?
Andrew, if you do not want the integrated setup that you have seen in the ARX, get an RS.
You will be hard pressed to find an RS with all the goodies, but it is the only option without the integrated unit.
RX, ARX and Axis al have the integrated unit and all RS's have the separate Clarion unit with 3 gauge DIN.
I am sure that you can always change the headunit over and connect it up with the integrated unit though.
Edited by iamhe77
OK
Is there a common work-around or fix for the radio in the integrated unit?
OK
V35 FAQ
See what Chris has posted regarding the BOSE unit. I presume it is the same for the standard integrated headunit, but maybe fire him off a PM to make sure what is involved in changing it.
V35 FAQ
Cool. Thanks.
Yes, no, yes.
Upgraded front bar on it's way, as is the bonnet... and I have the lights that you do so love.
I bet you have every thing crossed that it will all line up this time....LOL :)
Edited by andy65b
i know where there is a PM35 we can get the parts from cam :ph34r:
Nah, dark blue is not my colour....
Besides Ben was willing to sell be a PM35 bonnet, but the price was NOT right.
I bet you have every thing crossed that it will all line up this time....LOL :rant:
It will. The bonnet was the only issue.......... :) ...... I hope......
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
