Sorry, I feel like I've hijacked the forum.
Just one more question, someone raised the possibility of importing.
How is J-Spec as an importer? I know you can't bag out company's on here but there are ways to do that without actually doing it .... or you could pm me.
I have gone thru J-Spec,(soon to land an M35) after being referred by a work collegue who brought 2 cars thru J-spec, and I must say Ben has gone above & beyond, is very helpful and answers all questions if he can, and if he cant, he'll get an answer for you. Top bloke cant recommend him enough. I wouldnt hesitate to buy thru Ben again. J-Spec Imports
Hey people,
I'm having trouble buying two belts for vq25det on M35 in Autobarn as they had no listing at all. :rant:
Does anyone know aftermarket part numbers for these belts?
Thanks a milion.
Dave
Hey people,
Thanks a milion.
Dave
Belts are the same as 350z;
Alternator - 4PK950
Power steering Pump - 6PK1180
Link to belt "how to":thumbsup:
http://www.m35stagea...lit=belts#p1867
Edited by Daleo
yeh they are the same. just keep in mind that the pictures are different to the actual product,
we dont have camber adjustable tops.
which is why i bought the V1's, I couldnt justify spending an extra $300 just for a bees dick larger canister
Yes, that's them. Send Paul at Street to Track an email (I PM'ed you) & ask what the current price is. Mine are on the way (with custom spring rates) & were $1165 delivered.
But if you are in a hurry, Just Jap would probably get them to you sooner if they're in stock & you get standard rates.
Hey Aaron, since when does $1299 - $1149 = $300 (JJ prices)
lol @ your maths. What is it you do again?
Edited by Commsman
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
