225/55r18
This is what my tyre placard states, the law states you cannot ecceed + or - 15mm of overall diameter of factory wheel/tyre combination.........otherwise speedo will be out by a certain %
So you could run r22x30x245 if your hektic and that
http://www.alloywheels.com/tyrecalc.asp
I'm actually looking for tyres for my 19x.9.5's (when they show).
Some good deals in 245/40 R19 - HSV front end tyres from what I'm told, same as what spoolin is running from memory. They are 1.5% out.. So at 100kmh reading you're doing 101.5kmh.
sweet, what offset do you have to run 9.5 wide? Mine are 9 inch wide and they are just legal, but will be getting new wheels when the funds allow it.
http://www.alloywhee...om/tyrecalc.asp
Oh noes! Does that mean I'm breaking-law.jpg?w=385&h=240:banana:
Like a Baws.
Edited by Daleo
This is what I run; it gives around 3% error (100km/h indicated= 97km/h actual) against my GPS. thumbsup.gif
My tyre size is exactly the same as yours Dale, & my speedo reads 7% fast at 100km/h by my GPS.....
I think the satellites need recalibration.
Lol, well I get a different speed going in two different directions on the same piece of road; so anything's possible...
Maybe if they bring the satellites a bit closer to the earth?:blink: They're miles too far away, IMO...
Edited by Daleo
Jase, if you're wanting to fit the valve body upgrade at the same time as dropping all the fluid, I can sell you mine, that rocked up today, and just order another one?
I'm not in a hurry, especially since I changed the trans fluid when I got the car, around 6 months ago. So if you're changing the trans fluid shortly, better off doing the shift kit at the same time.
Evidently I have come into this with my eyes shut. What is this valve body upgrade? Not the shift kit thing that everyone is talking about? I don't think I have the mechanical confidence to tackle a job like that.
Yep, that's it. Mine came yesterday. I love the sticker on the front, but I don't believe a word of it....
Yeh....not hard at all.....you just don't want to make an error. Things often come with labels like that.....also throw the distructions in the bin as they have a whole heap of useless info in them too!
Seriously
If you have mechanical knowledge it's a can do....if your struggling to do anything on your car mechanically don't attempt it!
    • If I had "perfect R33 GTR" kinda money I would have bought one of the crazy expensive low mileage HJA cars, but I am sadly not that wealthy. I already picked this car out of various Skylines for sale locally, most of which were worse in some way. Only a few cars were actually better but also more expensive. In terms of buying a motor locally, I at least have the option to inspect it myself and juding the seller as a person, and used or freshly rebuilt engines that some people sell are actually ok price-wise. I knew the car was going to require work, but shit piled up real fast and I haven't even driven 1000km yet as the turbo started oiling like a bitch within a few weeks after I got the car.   I assume it wasn't actually me who cracked it, though there is no way to know when that crack formed and if the previous owner even knew it was there. Buying another 05U Block can be a gamble, yeah, but the cheapest PRP cast block is like twice or more money-wise, and billet is 3 or 3 times as much. For now I am most likely just keeping the current engine, as a rebuild or engine swap isn't happening right now. But I am seriously considering buying a second engine and selling mine in return. Might be a sweet deal at the end.
    • Hi all. I need some help buying the correct size banjo bolts for my 2860 turbos. Because whoever installed them tore up the original part, I ordered new ones of this kind, because I just figured these were the most leak-resistant option as I already had trouble with a shitty braided line. I need to know the thread size of the smaller left hole, that is the turbo oil feed connection. I found out so far that the turbo oil inlet apparently has a 7/16"-24 thread, but I cannot find any listing or description of the thread size on this line. I do not have the original bolts. I tried using the bolts that were in the turbos (the ones that were mounted with the shitty braided line) but they sit very loosely so they can't be the right thread. Means either these bolts are the wrong ones (how do they fit the turbo then? no clue) or the wraparound-lines have a different thread than the turbo oil feed itself. Help is appreciated, asking Nissan directly is obviously not going to work.
    • EDIT: PSA to whoever stumbles upon this thread. It is in fact a crack in the block that caused this concern. Just letting you know. In my case, a few cm long hairline crack going horizontally above the turbo oil feed. Classic RB shit I guess
    • Might as well pop in some cams, head gasket, head studs, and a flex sensor. Full send.
