Does anyone know if the standard M35 ECU can 'learn'?
After I changed the exhaust and dump I saw a massive increase in performance. On the dyno it looked to be 30kW and an extra 3PSI boost. Turbo starts to spool up now at around 2250rpm.
Then I fitted the pod, and on the Informeter saw I was running the injectors at 100% by about 6000rpm.
Then I fitted the HDI intercooler, and it seemed like it lost a bit, spooled up later, and was a bit more sluggish. I figured this was the lag introduced by having a bigger intercooler to fill.
Then I dumped the Valvoline oil, replaced it with Motul 300v, drove the car around 300km, and then let the car sit in the driveway for about 10 days.
Driving it on the weekend, it appears that the injectors are no longer hitting 100%, and the turbo is starting to spool at 2250. Sluggishness seems to have gone away, and it feels as good as it used to.
Would this be the ECU reacting to the mods, and relearning/retuning itself? Or would it be something else?
The HDI coolers have F all pressure drop so you wont notice any lag in boost unless you want to log a run and find it might 50rpm later lol
ECU's are gay and literally change a tune with a change of weather.
Does anyone know if all AR-X's come with the fixtures to buy and install the grate separating the backseats from the boot ie to stop my bloody dog from jumping over. From the pictures that have been sent to me it doesn't look like my AR-X has it standard.
If yes, does anyone want to sell me one.
Just so happens to be one on Yahoo Auctions at the moment.
Here is the Import Monster link
http://www.importmonster.com.au/view?url=http://page10.auctions.yahoo.co.jp/jp/auction/m89454506&thumb=http://f5.auctions.c.yimg.jp/img251.auctions.yahoo.co.jp/users/0/3/4/3/hotel_costes45_6-thumb-1319385762283631.jpg&title=M35
^That's a good price. Still, $375 delivered!
Also, pretty sure that all of the mounting "hardware" is included in all models. It should be up near the child restraining points. The lower mount is along the plastic trim along the bottom of the rear windows. There's little tabs that you press in and they pop out.
Edited by jasevr4
I could be tempted to part with mine if you need it. I only bought it a couple of weeks ago, but Northshore put the child restraint mounts in line with where the second rod goes, and apparently can't do anything about it. Otherwise I'll just store it under the floor till I need it.
Don't you use it as a divider for the back section rather the "seat to ceiling" position?
That's where mine always is. Stops the groceries from launching everywhere.
There are multiple configurations..
Those of you running some sort of digital gauges, what do you use to do so?
Does the M35 use OBDII? Can you get an accurate boost figure from this?
Greddy infometer seems to be the most common ....and we know it works....OBDII is correct!
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
