Does anyone know if the standard M35 ECU can 'learn'?
After I changed the exhaust and dump I saw a massive increase in performance. On the dyno it looked to be 30kW and an extra 3PSI boost. Turbo starts to spool up now at around 2250rpm.
Then I fitted the pod, and on the Informeter saw I was running the injectors at 100% by about 6000rpm.
Then I fitted the HDI intercooler, and it seemed like it lost a bit, spooled up later, and was a bit more sluggish. I figured this was the lag introduced by having a bigger intercooler to fill.
Then I dumped the Valvoline oil, replaced it with Motul 300v, drove the car around 300km, and then let the car sit in the driveway for about 10 days.
Driving it on the weekend, it appears that the injectors are no longer hitting 100%, and the turbo is starting to spool at 2250. Sluggishness seems to have gone away, and it feels as good as it used to.
Would this be the ECU reacting to the mods, and relearning/retuning itself? Or would it be something else?
The HDI coolers have F all pressure drop so you wont notice any lag in boost unless you want to log a run and find it might 50rpm later lol
ECU's are gay and literally change a tune with a change of weather.
Does anyone know if all AR-X's come with the fixtures to buy and install the grate separating the backseats from the boot ie to stop my bloody dog from jumping over. From the pictures that have been sent to me it doesn't look like my AR-X has it standard.
If yes, does anyone want to sell me one.
Just so happens to be one on Yahoo Auctions at the moment.
Here is the Import Monster link
http://www.importmonster.com.au/view?url=http://page10.auctions.yahoo.co.jp/jp/auction/m89454506&thumb=http://f5.auctions.c.yimg.jp/img251.auctions.yahoo.co.jp/users/0/3/4/3/hotel_costes45_6-thumb-1319385762283631.jpg&title=M35
^That's a good price. Still, $375 delivered!
Also, pretty sure that all of the mounting "hardware" is included in all models. It should be up near the child restraining points. The lower mount is along the plastic trim along the bottom of the rear windows. There's little tabs that you press in and they pop out.
Edited by jasevr4
I could be tempted to part with mine if you need it. I only bought it a couple of weeks ago, but Northshore put the child restraint mounts in line with where the second rod goes, and apparently can't do anything about it. Otherwise I'll just store it under the floor till I need it.
Don't you use it as a divider for the back section rather the "seat to ceiling" position?
That's where mine always is. Stops the groceries from launching everywhere.
There are multiple configurations..
Those of you running some sort of digital gauges, what do you use to do so?
Does the M35 use OBDII? Can you get an accurate boost figure from this?
Greddy infometer seems to be the most common ....and we know it works....OBDII is correct!
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
