Does anyone know if the standard M35 ECU can 'learn'?
After I changed the exhaust and dump I saw a massive increase in performance. On the dyno it looked to be 30kW and an extra 3PSI boost. Turbo starts to spool up now at around 2250rpm.
Then I fitted the pod, and on the Informeter saw I was running the injectors at 100% by about 6000rpm.
Then I fitted the HDI intercooler, and it seemed like it lost a bit, spooled up later, and was a bit more sluggish. I figured this was the lag introduced by having a bigger intercooler to fill.
Then I dumped the Valvoline oil, replaced it with Motul 300v, drove the car around 300km, and then let the car sit in the driveway for about 10 days.
Driving it on the weekend, it appears that the injectors are no longer hitting 100%, and the turbo is starting to spool at 2250. Sluggishness seems to have gone away, and it feels as good as it used to.
Would this be the ECU reacting to the mods, and relearning/retuning itself? Or would it be something else?
The HDI coolers have F all pressure drop so you wont notice any lag in boost unless you want to log a run and find it might 50rpm later lol
ECU's are gay and literally change a tune with a change of weather.
Does anyone know if all AR-X's come with the fixtures to buy and install the grate separating the backseats from the boot ie to stop my bloody dog from jumping over. From the pictures that have been sent to me it doesn't look like my AR-X has it standard.
If yes, does anyone want to sell me one.
Just so happens to be one on Yahoo Auctions at the moment.
Here is the Import Monster link
http://www.importmonster.com.au/view?url=http://page10.auctions.yahoo.co.jp/jp/auction/m89454506&thumb=http://f5.auctions.c.yimg.jp/img251.auctions.yahoo.co.jp/users/0/3/4/3/hotel_costes45_6-thumb-1319385762283631.jpg&title=M35
^That's a good price. Still, $375 delivered!
Also, pretty sure that all of the mounting "hardware" is included in all models. It should be up near the child restraining points. The lower mount is along the plastic trim along the bottom of the rear windows. There's little tabs that you press in and they pop out.
Edited by jasevr4
I could be tempted to part with mine if you need it. I only bought it a couple of weeks ago, but Northshore put the child restraint mounts in line with where the second rod goes, and apparently can't do anything about it. Otherwise I'll just store it under the floor till I need it.
Don't you use it as a divider for the back section rather the "seat to ceiling" position?
That's where mine always is. Stops the groceries from launching everywhere.
There are multiple configurations..
Those of you running some sort of digital gauges, what do you use to do so?
Does the M35 use OBDII? Can you get an accurate boost figure from this?
Greddy infometer seems to be the most common ....and we know it works....OBDII is correct!
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
