  • Replies 42
r32 its part of the bumper r33 cant really remember i think its seperate on them, i'll check later. If in fact it is removable on the r33 i think you would have to remove the bumber then the tail lights. First though look under the trim cover in the boost it might just bolt up from behind. Why you wanna remove it?:)
https://www.sau.com.au/forums/topic/1856-skyline-rear-pannel/#findComment-34754
yeah on my 32 it looks like the "SKYLINE" bit is just glued onto the bumper though... and its completely clear like made of glass the word... I so wanna set up red LED's behind it, but I'm too scared to rip the little **** off in case I can't put it back on lol
https://www.sau.com.au/forums/topic/1856-skyline-rear-pannel/#findComment-34761
oh ok yours sound like laminted vinyl letters if so be carefull i pulled them off on my old silvia n they pulled the paint up. The r33 is a seperate panel just checked then it goes between the blinkers it shouldnt be too hard to get off.
https://www.sau.com.au/forums/topic/1856-skyline-rear-pannel/#findComment-34763
Man you can't beat the factory Item,,,,Mines Green at night. Pity the "E" doesn't work,,,so I own a "SKYLIN".
Search this Forum,,,,,MYGTST has posted how he did it. I think he's got his connected to his Brake lights if I'm not mistaken.....It does look cool.
Neil.
https://www.sau.com.au/forums/topic/1856-skyline-rear-pannel/#findComment-34826
thanks for all your help guys, i knew it'd have to detatch as u can swap them for the Green Aluminouse style like NDR has, they look very sweet too!
I wanted to remove mine so i cant paint it the same colour as the car (call me sad or a tryhard series II person but what can u do i like the look better)
I'll give it a go on the weekened :)
https://www.sau.com.au/forums/topic/1856-skyline-rear-pannel/#findComment-34844
Originally posted by ONARUN
i would've posted them earlier if they came out God. they were all dark and crap. sorry your eminence, i failed you. take this goat as a sign of my regret
A GOAT??
you cheepskate!
https://www.sau.com.au/forums/topic/1856-skyline-rear-pannel/#findComment-34984
Yes my tall young Disciple and my failed Youngster,,,I am old but wise. Surely after all my teachings you the Tall one have a picture somewhere.......
Fail me oh Tall one and your regime will be forwarded to the Devil as the Failed one has. I have sent the Failed ones Goat to Holden,,,,,They will be re-labeling it as the new VZ.
God.
https://www.sau.com.au/forums/topic/1856-skyline-rear-pannel/#findComment-35024
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
