I just took a careful look at djr81's rotor photos - on my as yet uncracked DBA4000s, the slot is NOT machined all the way to the edge like it is in those photos. It stops a few mm short. Perhaps they updated the design?
  • Replies 177
Posted Images
djr...they don't make 5000's for the rears which is why I was considering 4000's :wave:
Also had a look at greenline and nengun and for the life of me I can't find mu or endless rotors for the rear of a 33....am I going blind?
No you are not.
Sorry for the bum steer. I thought they did. Dodgy memory.
I think the reason is that the handbrake works on the inner drum section (or hat if you like) So no one makes the hatted rotors for the rear.
They dont make any 5000 series at all for the povvo pack 32 R's either.
Except for a mob called Biot who appear to.
Edited by djr81
Hmmm so you can't get rear rotors from greenline/nengun and the RDA's and DBA's crack with track use....
Whats options am I left with to replace my worn stockies then?
You can get plenty of rotors, just not hatted ones. Check the usual imports mobs. Endless/Project Mu. With the way the dollar is going lately they will be practically giving them away....
The Biot stuff looks well bling if you can get your hands on them.
Maybe AP or Brembo do one also. Big $'s, but.
Edited by djr81
Actually looking at the difference between djrs and mine it looks like they may just machine the a 324 to bring it down 296 - look at the way the vanes go all the way to the edge on the 296's and are smoothly machined, where as the 324 still have the cast finish and stop well short of the edge. Perhaps they further machine poorly cast 324s to make them saleable as 296's....
Reckon you may be onto something there. :wave:
Notice also how much wasted rotor face there is on the inside of your rotor.
just because nengun says so doesn't make it true. I have bought from project mu scr pro rear rotors for BCNR33. yes they are 2 piece and have the drum built into the hat. :wave:
LOL...for the rears im thinking std Nissan with some home made slots machined into them :wave:
Im all for the fish hook or long curved slots like the G4 as there are less likely to be stress concentrators.
Im just going to sell my car and get a Mk 1 Escort. Single piston sold rotors are less complicated and up to the job when you have a 650kg 180hp car :(
Lol Baron....I wasn't suggesting that to be the case....I just need to find someone who will supply me the rotors here in Oz.....does anyone know who I could contact?
  • 1 month later...
just because nengun says so doesn't make it true. I have bought from project mu scr pro rear rotors for BCNR33. yes they are 2 piece and have the drum built into the hat. :P
Sorry to bring this up again, but from where did you order them? I can't find anyone who either lists them or is willing to admit they can supply them...
And DBA are not talkign to me now, perhaps they dont want to lie as their investigations may have revealed that my installation was in no way at fault :P
Anyway, if they dont do something to stop the failures or at least properly educate those installing them then they are going to continue to lose lots of business, shame really. I woudll rather run used std Nissan rears then anything DBA, and its not because of money, just confidence in th :(e std product doing a better job then anything dba sell :P
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
