Is there any way to tell if they are premium by the VIN number?
Seems like it would be a more reliable way of working it out
Pretty sure you can run VIN trough Nissan FAST and see what options it came with
this will not deter every dealer telling that every V35 they sell is premium :)
Ok thanks..that's what I thought...don't know about the Brembo brakes though because I though they phased those out after Series 1. Oh well, will know in 2 weeks time when the car arrives.
From what i know the 19 inch wheels came on the sport model, which had the LSD and Brembo brakes but i could be wrong.
  • 1 month later...
  • 3 months later...
Just wondering does series 3 have different criteria to distinguish premiums and non premiums?
I have leather/suede seats
Dual climate
Auto lights with bi-xenons (standard on all 2006 models)
Steering control
However I'm not sure whether it has a Bose stereo or not. The centre console is different to previous models and there the MD player is, it says MD ---(something) instead of Bose... The sound system in the car is quite good. Can any other 06 model owners verify this?
Also someone mentioned 06 premium models have sunroof and keyless engine start, but i thought they were only for US models.
Thanks
I have a series three also (dec '05), If you open up the glove box where the Nav DVD thing is you should see a bluetooth logo.
From what I remember if it has bluetooth it is a premium series 3. Mine has the 19's, half leather and steering controls, bi-xenon, dual climate but no bose. Unless it actually says Bose on the MD player then its not. Not sure about LSD etc. After the first couple of years almost everything seemed to be factory options etc so it just got hard to tell. But i'm fairly certain that if it has Bluetooth, its a premium.
Edited by dcmudge
Thanks for the reply. Mine has the bluetooth logo and the Bluetooth button on both the centre console and the steering wheel. 6 disc cd changer but no Bose on the MD player.
If it is a premium doesn't it come with the Bose stereo?
If you have a manual + I think rays 19 inch factory wheels then u are likely to have LSD
  • 1 month later...
Hey guys,
Just been reading through here trying to figure out just what spec it is that I have. I think on the first page it was listed; I have the head deck with the flip-out (rather than the dash mounted "pop-out") screen with the DVD ROM built into the deck rather than above the glove box. I tried (and succeeded) in playing regular DVDs on it also.
I've been told from Xanavi Australia that this series system cannot be translated from Japanese to English either (wrong thread, I know).
So I'm just wondering what sort of package I have. It's a 2003 350 GT.
Thanks.
Hey guys,
Thanks.
I'm guessing yours is already moddified
  • 3 weeks later...
It must be pretty picky with DVDs also. I just tried with another DVD and it wouldn't play. How do you mean modified, man?
if your trying to play DVD's on it, remember that Japan's DVD region is completly diffrent to ours. so unless you have a region free disc, or a REGION 2 DVD. it probably wont play :)
  • 1 month later...
Premium comes with dual climate control and bose sound system. I'm not too sure if heated seats are an option on the premium though.
Mine is premium and it didn't come with any Brembo's (common misconception for premium model).
Its from the Auction....... the people who bidded on this car for me at the auction told me it premium model cause its got 18s and comes with half leather..... but i never trust them from what they say.
From what I have found, the only 'premium only' feature on the S2 Sedans is the Bose audio. everything else can be optioned on the non-premium model. I have a non-premium, but have dual zone climate control and steering wheel audio controls.
I think the coupe premium also got leather seats, but again, that may have been an option on the 'non premium'
  • 1 month later...
So i have seen alot of arguments about premium, the real issue here is working out what ones have a LSD in them when looking on the auctions, im in the process of working out if its worth getting a manual with brembo/LSD and turbo kiting it or just doing it to my 5AT that i have now, any ideas on how to pick the "track" spec out with the LSD would be great.
  1. You can identify this so long as you get the 6 digit model number (i.e. the CPV35 - xxxxxx) from the auction sheet.
  2. Use this link to input in the 6 digit number (in the following format CPV35-XXXXXX) in in order to get the Nissan Fast 18 digit code. http://jpcenter.ru/month
  3. If the 17th digit of the Nissan Fast code (second last) is a D, then you have LSD. If it is a dash, no LSD.
  • 2 months later...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
