  • Replies 138
is the response is pretty good? full boost by XXXXrpm?
Good power for low boost to :(
im pretty sure i had full boost by 3500 rpm, but i have to check it out again. was raining last night and i had to drive like a gran.
And thanks :(
well done mate :worship:
my guess was 251.2rwkw
so thats what i wanna see on 16psi...................right !?!?!? :(
and yes, i believe you'll have no problems with the new bov. GFB bovs are very decent.
a gtr bov probably would have done the job too.
Edited by Munkyb0y
im sure i can do it.
and thanks :)
Hey guys finally im ready to finish off my car. really anxious!! Existing mods on my r33 gtst which i made 209rwk
-pfc
-blitz fmic
-ebc
-sliding performance hiflow turbo (non vg30 rear)
-3in turbo back exhaust w hiflow cat
-k@n pod
-stock fuel pump
-stock afm
-stock injectors
-ran 13psi
new mods and retune with these extras
-tomei intank fuel pump
-z32afm
-500cc hiflowed injectors
-hks actuator
-going to run 17psi
what will the final figure be? Take a guess.
Question....who did the highflowing of your injectors???
Depends how happy the dyno is.
I would say between 230 to 250 rwkws....
Whats the prize anyway......do we get to eat the smarties in the jar :)
I won the smarties.... :)
240kws...smack in the middle
quick question guys. i just finished installing the new bov and it keeps stalling when i clutch in as im slowing down in 2nd.
ive tightened it up and it just makes the psssh noise. dosent "flutter" anymore...
did u plumb it back? or leave it atmo?
atmo will give you issues alot of the time. it did on mine to a degree. occasianally stalled, idle was a bit tempremental, and the psshhht gave me the shits.
i plumbed it back, no more problems.
edit: i've got the GFB hybrid bov
Edited by Munkyb0y
i plumbed it back
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
