Hi All,
I am converting a r33 gtst from auto to man. I am having trouble getting the auto spigot bush out.
I have tried using the wet newspaper with a bolt trick but its not working at all.
Has any body got a spigot bush puller they can lend for a day, I really need it out as its holding me up.
Also, anyone got any other techniques.
Cheers
Daniel
https://www.sau.com.au/forums/topic/186993-spigot-bush-help-needed/
Had the same problem converting an auto Stagea engine for a manual box in my 32. The usual method is to fill the hole with grease, then punch a gearbox input shaft into the hole.
However, I ended up resorting to a wheel stud tack-welded onto the bearing, then use a drift hammer to pull it out.
I have tried the equivalent and to no prevail.
The wheel stud you used, was it a perfect ft into the bush or was there 0.5mm - 1mm gap give or take each side.
Cheers
Don't remember - it was 3 years ago, and I'm suffering advanced dementia :laughing-smiley-014:
It doesn't have to fit - the weld will bridge the gap.
sorry to ask a dumb question....but why would an auto have a spigot bush? what sits in it?
I assume its in there for the torque converter and this ones a steel item it doesnt wear down, where the manual bush is brass and slowly wears down overtime. I think this is correct :down:
normally i use grease, but if you cant find a perfect fitting bolt to bash in there try using blue tack.
hasnt failed me yet. and also doesnt destroy the crank if you miss hit with the chisel idea from above..
I had another go at it today. Went to the bolt shop and got almost a perfect match for it..still wont budge, the newspaper keeps pressing into the thread.
The glue tack idea sounds good. I might try some grease instead of the wet newspaper too.
Cheers
For mine I went to the local hardware and bought a suitable size bolt (like 16mm or so as mentioned before), CUT the thread of the end with a hacksaw and cleaned up the edges with a file, then filled the back of the crank with grease and gave it the FBH (f@cken big hammer) approach and it popped out easy as. The bolt has to be a tight fit - ie you have to hit it in with the hammer, and after a short amount of time it came out easy as. Cost me a couple of dollars - tried heaps of other methods before I finally gave this a go - was completely suprised at how easy it was. You then can keep the long bolt 'genuine spiggot bush remover' in your box of tricks for next time. As they say - the right tool makes the job easy! Good luck :-)
you sure the brass bush doent just fit inside of it? i dont see the point of having a bearing for an auto when the crank and torque convertor dont turn in each other unlike an input shaft of a gearbox. ive converted an rb30 auto to a manual and all you have to do is fit the bush
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
