well here's some pics of the r34 last week and i will post up some pics of the car tomorrow night, should be nearly just a shell, not bad for a day and a halfs work,
then we need to make a chassis frame so we can rotate it and also use it to ship to sydney to get the shell acid dipped.
i will keep ya's posted with it's progress
  • Replies 705
Posted Images
yes it's a really nice car,
bloody dirty under neath though!! friggin road cars, who'd work on em! lol
i promise you it will be reborn!! this thing is going to be something special, you should see the gear for it!!
didnt get the car finished(stripped) should have it ready to take to work and take the subframes & glass out tuesday,
there some really cool engineering changes from the r32 to this, great to pull it apart and see all the differences.
mind you i have never worked on an unmodified r33 so big differences for me.
and my baby has come back! it came back friday and i spent saturday night cleaning it! lol ( drank bourbon , i have been stressed about getting it back from japan)
speak soon guys
russ
yeah, who would put aftermarket wheels on that look like poor copies of the real thing & talk about bloody heavy!!
the front bar is genuine nismo it's got a badge and part number fibre glassed into it! & nismo lights in it.
No diffusers so non v spec hey. At least you won't have to worry about that issue I was telling you about.
Also - not sure what your diff plans are right now but I ditched my V Spec diffs for a standard non v spec (but tightened) mechanical one and I can't fault it at all. Its definitely better than the V Spec one was.
PS - Bayside Blue R34's FTW :D
if it's a non-vspec diff you should be able to buy the clutch pack upgrade from nismo/nissan for the rear. they are quite good with that upgrade. other than that I have no idea how to choose between them really. cusco/tomei/nismo/ATS/kaaz/OS Giken they all make GTR diffs and all have their fans. for this car considering it's all out balls to the wall maybe look at a pair of carbon diffs.
Russ - basically what Baron said. Standard Nissan diff with upgraded clutch packs. It's brilliant. That was kinda what my point was to tell you if you didn't already have diff plans to just get the one you have upgraded to start with.
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
