just back from the tuners its like a new car just got a gt3076r installed running 16psi on low boost setting and 21psi on high boost settings. any one tell me what this dyno sheet is telling me. looks like at the top end its letting go. could this be cams?
i have all the supporting mods.
cheers
https://www.sau.com.au/forums/topic/187275-just-got-r33-from-tuners/
PS, i have no idea how or why Cams would give you jumpy power like that.
I really doubt that's what it is, and the power level (250) isn't anything that Cams would have a problem with.
I guess what i'm saying is that Cams could handle 2000rwkws as long as the engine and turbo were up to it.
The only reason you would change Cams is to improve power gains across the rev range etc....
Nothing wrong with standard though if you're punching more air in.
Two distinct dips but not shaky looking graph line.
I'd suspect 1-2 degrees of timing taken out to address knock. A look at your ignition map will soon tell. :)
The over 4000rpm results looks good, but what do you think about things under that engine speed? Looks a bit lazy to come on for you. This spec should be generally similar to The Mafia, and he's pulling 300kW out of 18psi + a much more linear looking curve throughout the range with the assistance of water/meth.
Edited by Dale FZ1
I'd suspect 1-2 degrees of timing taken out to address knock. A look at your ignition map will soon tell. :P
whats your timing degrees tuned at? if you take out 1 - 2 degrees timing, you will get slightly better mid range power but less peak power..
Previous posts by Murat, and the comment about "all supporting mods" indicates he has a PFC.
I'm suggesting it's in the spark mapping ie adjusting one or two specific cells in the map, not the base timing being adjusted by a degree or two :)
Could be wrong but that's where I'd look if there is a concern/query about the shape of the graph
Edited by Dale FZ1
Explain to me how removing timing is going to improve his midrange???
Id really like to know!
It looks like the exhaust housing may be to small If its not retard to much in the topend.
What sort of timing is it running through the top?? and like others have suggested what exhaust housing are you using??
core number is 700382-5012
compressor housing is .60A/R
turbine housing is .82A/R internal wastegate
if that helps is there any one i can take the car too give me a hand with the problem?
money is no problem.
dude, thats the same turbo as me. (GT3037) I make 15psi by 3900rpm in second gear.
The bigger rear must give it a bit more lag hey?
Also, can you list your supporting mods?
I make just over 300rwkw at 18psi on this turbo.
Engine management - PFC
Boost ran - 18psi
Turbo - Garrett GT3076r
Nismo 740cc injectors
Bosch 040 pump
Gready EBC Profec II
Z32 80mm Air Flow Meter
Hybrid Intercooler
3inch Exhaust turbo back
Splitfire Coil Packs
Stock Internals
no head work
Fuel pump
its not that bad i get about 15psi by 3800rpm its depends on the engine load at the time 5th gear its full boost by 3500
thats strange, as I have almost the same setup, but with a smaller turbo rear.
That wavey line looks dodgey. Are the AFR's staying safe while it is doing that? Is the fuel pump healthy? You'll need to test your pressures.
AFR are safe its is running rich because after about an hour of driving the back bumper has a light black color, fuel pump was installed about 3 months ago brand new, what i will check is the cat see if it is choking and do a pressure test, i know i should be getting abit more becuase i have read your 300kw advantage this is what i have built my car from. so im abit shocked.
anything else you reckon i can check out ?
i have notice one more thing with the car the idle is very high sits at about 900 to 1000 rpm, i tried to reset it to a lower figure but it still sits up at 900 to 1000 rpm could this be a connected problem?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
