yeh, think they are heavy. i know yella terra re-designed them so would be interesting to see the new ones.
i will be putting a set of Harland Sharp rockers this time though.
Any idea what the issue is with the roller arms? too heavy and causing valve float / bounce?
  • Replies 812
got through a bit of work this week, removed rear boot latch and fitted some bonett pins on the boot lid to make it easier to access the fueltank and eliminate the risk of loosing the key and not being able to open the boot.
Purchased a GT style rear wing, 1500 wide and sits just over 300 off the boot lid. Great fathers day present, thanks girls.
have began lowering the drivers seat which we should finish tonight. Also going to lower the fuel tank to drop the centre of gravity as it was advised this could aid in helping with handling in the rear of the car.
Still waiting for the front bumper. Might give the air ducting/engine cover a crack on the week-end.
Your build is mint and i didnt want to be critical of an awesome build, but i was left wondering why you threw the fuel cell up high in the boot. Throw back in the std jobbie, or GTR as i am told they are plastic and lighter, ...or better yet make up a 30L smaller alloy jobbie that sits under the car but in front of the rear axles...perfection.
I am reading all these build threads whilst stuck in a hotel room and so keen to ge tback to Aus and getting something going
i guess i did it this way as the tanks are cheap and it was easy to modify to run the internal pumps and because ive set up to many fuel systems on drag cars lol. If i run a standard tank i would have to run a surge and i just wanted to keep it simple. My setup only runs a feed, pressure is regulated at the tank.
Ill drop the tank into the wheel well and the sump will hang through. Its minimal work to do this and i wont have to re-plumb anything.
i
OK, the wing is on......and im not sure about it. maybe it will grow on me but at the moment i think its ricey, when i see it all i can think of is honda civics or mitsubishi lancers. i hope it gives the downforce it looks like it should or its going to get the ol heave ho. Anyway can always sell it to a drifter lol.....which makes me wonder why they have wings anyway.
im still waiting for Vin Diesel to climb out of it....
The wing is glass with a wrap. The uprights are cnc machined alloy and pretty serious though and it has large endplates.
i bought it second hand over the net. Dont know who makes it....could even be a custom job but not sure.
It looks alright Stu, Is it carbon?
also any idea who makes it / sells it?
Started on the air dam today. Used a fibreglass bonnet outer skin, marked it out and slowly got it to sit around the intake.
still have to glass up the sides and fit mounting brackets but you can get the general idea...
ha ha, driven a commodore lately? with the amount of off the shelf parts and interchangeable parts available for a Nissan, let alone the body shape of the R32 which is small, and arguably the best ever made, the combination was good. And im not sure what a Commodore has to do with it, if i had the coin i would have bought a Vet.
The thing is i always wanted the Skyline, the engine popped up by chance. Ive owned one taxi and ill never go back....
After all this man why did you put a v8 into your 32??? shoulda just bought a commodore if u want a v8!
got intake dam back from fibreglasser today and he had done a top job, we trial fitted it and it was near perfect.
finished trimming the sides down and fitting dzus fasteners tonight. It will do for sunday, ill get it painted after that.
also fitted passenger seat and harness for the track day.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
