  • Replies 812
ok, serviced the car yesterday, nothing special, just oil & filter. also dropped the rubbish nulon gearbox oil out and replaced it with some Repsol synthetic matic atf. Much better.
checked and adjusted the wheel alignment,
running 6 deg caster, 3 deg neg camber and 1.5mm toe out on front.
3 deg neg camber and 1.8mm toe in on rear.
will see how it goes. Bring on wakefield.
Had a great day at Wakefield, eventually got the tune sorted after datalogging a few laps, car was very lean in places so happy to get it sorted.
Diff is tired, needs a re-build, tyres also tired, so am i, but happy with the car.
managed to real off a few 1.08s in the last session which was very good.
hope to get diff done and some tyres for SAU track day.
yeh this one is, id speak to an engineer first.
Can i just ask somethign (and i'll be honest i haven't read the whole thread) but is this a track only car? As im looking to do an LS* V8 conversion on an R32 but am aiming for street use..
you may run into issues with the "you cant putting a V8 into a car under XXXXkg" rules
yeh not sure, ppl are putting vh45s in s13 silvias, whats a few extra cubes. whats a street trim 32 weigh?
Thankyou craved!!! 6.0L NA will do perfectly then!
Will have a detremental affect on turbo'ing it though....hmmm...oh well...as long as i can do it that's the main thing!
Is it true when you put a GM V8 in an R32 you have to for go the power steering?
They don't need turboing... It'll go like hell without one!
Think about it, take a VE Commodore with a 6.0L, what're they, 1.6T? Now drop 250KG... Throw a cam in, exhaust, tune done...
I'd have done it to mine except people want too much money!
there are also startermotor relocation kits available now which puts the starter on the other side which would solve all the issues. if your 32 goes 1350kg, you will be 450kg lighter than a VE, trust me, you dont need to turbo it. the car turns 3rd gear for fun. the torque is massive.
found a thread on sump extensions and baffeling, going to do this before next track day.
http://www.performanceforums.com/forums/sh....php?t=67247482
Oh really? sweet! that'd be better than not having powersteering lol
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
