General Meeting - Tuesday 16 October
It's SAU Vic Social Meeting time. That's right, Beer, Food, Beer, Cars, Beer and laughs!
These social meetings are divided into two parts, the first if your hungry is a meal from the bistro and a chance to have a chat with other members then the second is a short informal meeting.
We use these meetings to give quick rundowns on past events with video's, pictures and stories etc, to address pressing matters, tell members what's happening behind the scenes and for discussion on upcoming events. It's all pretty relaxed and fun. This is a great opportunity for those of you who don't know too many members to come down and mix as new faces are always welcomed.
Time - 8:00pm (Dinner from 7:00ish)
Date - Tuesday 16 October 2007
Location - Bell's Hotel, 157 Moray St, South Melbourne (Cnr Moray St & Coventry
St Melways Ref - 57, G1) - see map below
Note - This Pub is family friendly with an area set aside for us. There is plenty of seating (tables and chairs) and meals for all.
Who is welcome - Everyone!
MERCHANDISE
- ALL Merchandise will be available for sale at this meeting. Come see me.
- This includes a new delivery of SAU Polo Shirts. So we now have both colours in all sizes.
EVENT REVIEWS
- Morwell
- Drag Day @ Heathcote
UPCOMING EVENT DISCUSSION
- NSW Road Trip
- Annual Show N Shine / Xmas Party
WHAT ELSE WILL BE HAPPENING:
Guest Speaker -
Chris Muscat from Centreline Suspension will be giving us a run down on all things suspension.
Presentation -
We will present trophies and prizes from the Drag Day at this meeting.
James' Car of the Month -
From Lada's to Lambo's - what will we see for Show N Tell this month (let's face it - chances are 'something' will pop up though) :(
Hope to see you all there.
Map:
https://www.sau.com.au/forums/topic/187923-general-meeting-tuesday-16-october/
From Lada's to Lambo's - what will we see for Show N Tell this month (let's face it - chances are 'something' will pop up though) ;)
The longer James snubs his adoring minions, the more unlikely it becomes he will grace us with anything better than a Lada (he could always try for a Skoda)
An awesome speaker is lined up for October!!
Chris Muscat from Centreline Suspension.. he's also:
1990 Club Car Champion.
1st in Class 1995 Bathurst 12hr.
1st team Winton 24hr 1992.
2002 Victorian Sports Sedan Champion.
and probably more stuff I don't know about ;)
He'll be chatting about everything suspension - track and drift setup and what you can do to improve handling and the like.
You could just barrage him with a bunch of questions about his racing days though, caus that's always entertaining! :(
He gives advice at track days all the time, so it should be good :D
Come listen to Pete talk about his new wheels....The tale of high adventure!. How he hunted them down and had to slay dragons to get them. To having to fight hordes of people to get them out of the paintshop. To only have to kill the people who fitted them because they didnt use cotton gloves...cant wait to hear all about it....down a few schooners then piss on your new wheels :spank:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
