hey all ive started installing my new turbos and well i have them mounted but i didnt put the drain pipes on b4 i put the turbos on.
now i got the back one on no probs but the front seems a little more tricky.what i want to no is,am i kidding myself thinking ill get the front one on whilst the turbos mounted?
anyone else done this way?\
regards kane
https://www.sau.com.au/forums/topic/187941-installing-gt2860r-on-r32-gtr/
Get the proper generic drains for that cartridge with the proper bolt hole seperation from MTQ turbos and start again. Make sure you change oil feed restricotrs to the turbo's to. Use about a 1.5mm restrictor as those turbos are known to smoke a little with standard restrictors.
the drainpipes fot good now i modifyed them,i just forgot to put them on b4 installing the turbos?i got the rear one on ok.i was told the turbos are restricted already?anyone else confirm im right/wrong????? thank rob82
Kane
You will need to slot out the standard oil drain to fit the 2860-5. Pita as it doesn't need to go and awfull lot but enough to make you spend a bit of time one the round file - unles you're a lucky bugger with and air file or similar.
I got fussy and trimmed the gasket to fit all pretty.
Cheers
ps my 2860-5 had what looked like oil restrictors fitted when i got them.
Kane
Cheers
yep all slotted out,and they fitted perfect 4 i installed the turbos.but the thing i need to no now is,can i put the oil drainpipes on once the turbos are installed?there bolted up and the oil and water lines are on BUT i forgot the drain back pipes b4 installing.so is it possible to install after the turbos are ion the car....rear drain pipe is ion but the front isnt and its a bitch.....??????????
Haha its funny that everyone is discussing different sized oil returns and restrictors blah blah where i think hes asking is it physically possible to install the front oil drain with the turbos on....
It IS possible if you can manage to do it yourself, but if you cant then its not possible.
From memory its tricky even on the bench cos the lines to the core get in the way...
thanks and yes you are correct..:P
yes mate it can be done, i did it not easy but do able
thanks ill now keep trying
Edited by gun32gtr
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
