  • Replies 241
Posted Images
  • 2 months later...
hope everyone can see the amount of hours and recreation is needed to come close to a decent fit.
1 of a kind...
Rims are on.. and No spacers sitting right now.. maybe a 10mm or 15mm is fine but sits decent to me.
the Panda style look wasnt intentional.
the front bumper is only there for test fitting.. I have an OEM front bumper for the final fitting then paint.
in these pics.. its the r34 trunk... with the R32 trunk section about 2 inches from the window.. it was needed to be modified since the r34 trunk fit contoured well, but didnt come close enough to press down against the trunk inner weather stripping seal. Oh well... I guess it has to be done properly and right the first time.. Right?
or maybe im building a R34 Japan Cop car?
  • 3 weeks later...
those rear lights aren't GTT lights are they? don't seem wide enough for the rear guards?
Im glad you asked:)
The white taillight covers were CLAIMED to be GTR taillights when i bought them from Ebay 12 months ago.. but oh well.
1 more piece to the puzzle.
Damn Yokohama Nissan, teasing me with Midnight Purple 2 painted R34 GTR taillight covers...
No more panda project now.
Stay tuned the next few weeks... it will be a work of art.
wow awesome thread, i will keep coming back here for updates :) my dad is in canada now for work, and he called me to say they are using r34 sedans as taxi but they look different, he quickly called me back to say its a chevie impala lol
looks great, and looking forward to seeing the finsihed art work :(
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
