Cara you will need to sell your wheels to clear the brakes. You will need 18x8/18x9 +30 at the highest. Even my 18x10 +18 on the front, another 1-2mm and it would hit. Just make sure u choose the right offset and "disc" design on the wheels to make sure it clears.
Screw spacers, dangerous, stupid and illegal. Not to mention, if you are caught with them in an accident, insurance companies aren't generally too happy
Just get rims that fit correctly in the first place
Regardless, if I were to drive a car anywhere I wouldn't do it with spacers... that's just me though
yeah i just removed mine a couple weeks ago... the wheels look a bit better without them in my case...
cara dont u have 19's ? surely that should clear the calipers?
-D
Just because she has 19's Ben, doesn't mean she has a decent enough offset to clear larger calipers.
Good idea Steve, but I still don't think they are legal
not by rule of thumb but most 9's have a fair amount of caliper clearance considering people often need the bigger rims to clear the big calipers/bigger discs... its a chicken/egg thing
and ive seen her rims, theyre pretty bloody huge :laugh:
-D
Edited by Dohmar
i wouldnt say bolt on spacers are dangerous. I used 25mm on the back of my 31 while drifting for quite some time. They will be going back on the front sometime soon also. Never had a problem. Just make sure you buy hubcentric and get them from somewhere reputable. Adelaide tyrepower is where i got mine from.
cara, if youre spending $xx,000 on an engine package, $2k for some low offset jap (or china, whatever) wheels isnt that much of a stretch is it? sure spacers are a good short term fix, but buying proper wheels would be better.
but then, thats me, im getting annoyed running 5mm locating ring. :down:
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
