Nothing wrong with saying "Mr Squiggle", just confused is all.
I have been testing centrafuse on my laptop, which will become my carpc. I am not too sure which to use though, i want something that is going to be easy to get working with the haltech software so i can get the gauges etc working.
Centrafuse or Ride Runner will give the best compatibility for that sort of stuff imo, but rr is butt ugly. Is your laptop one of the ones that turns the hdd off if it detects a bump (most new ones do)? Cause even around the city streets it's enough of a bump and totally killing my music video playback and lagging software. Thinking maybe a mini-itx setup is in order.
Edited by nicr4wks
LOL Matty, where did you go?
Just quietly, we need to convince Luke into getting a 4x4.......he's apparently contemplating the idea!!
a lil spot out near edinburgh. have to show ya sometime........give the 200 a nice brown hue to it
just went and cleaned it after work at the big bucket at bedford park. mental note, dont use the very right hand wash bay unless they've cleaned it up haha
1 hour and 28 bucks equals a clean car (engine bay and outside, and MOST of underneath that i could get to). The rest i'll get on friday when i chuck it thru the auto wash for its weekly clean
anyone recommend a wireless key board and mouse?
Logitech or MS like Luke says. incidentally the MS keyboards are all made on logitech fabs
I like a wireless mouse and a wired keyboard, mainly because the logitech g15/g19 series are awesome and a standalone mouse usually has better resolution than a combo wireless mouse
and as for car pc's, you'll want solid state drives all the way, but im not sure if the eee would be the best bet for a permanent installation - theyre good in the glovebox but if you want a permanent solution then a dedicated car pc or a mac mini with aftermarket ssd would do the job quite admirably. Best mount point would be either under a seat or behind the rear seats between the rear strut towers and just run a db25 vga and usb to the front to the touchscreen head unit
-D
Some cock tried to steal the 33 on the weekend. :D
A club lock and alarm kinda ruined it for them :worship:
I'll remember to turn on the surveillance to the outside cameras from now on ... so I've got an idea of who's trying. :)
I have no idea if it will do that, plus a HDD skipping would hardly miss much/if any of a song or movie. The laptop i got is a Acer 5315, got it free from work, i am going to upgrade the cpu in it when i can be bothered pulling apart a HP at work.
-D
I am going to be placing the laptop in the spare wheel well, may also move the amps into there aswell, and have a mdf/false floor in the boot. Then run a VGA and usb cable tot he front of the car for the touchscreen.
Does anyone know much about ET pulsar's? a friend of mine has one that isnt working and is wanting to sell it, i am thinking of buying it and fixing it.
yeh i do a bit, had a blue one with a high mount high flowed t25
the gearboxes are crap especially reverse, and the factory computer is also crap as it is located under the passenger seat which is easily knocked by the passengers feet which in turn pulls out the loom
other that they are a great little FWD car
Some cock tried to steal the 33 on the weekend. :down:
A club lock and alarm kinda ruined it for them :D
I'll remember to turn on the surveillance to the outside cameras from now on ... so I've got an idea of who's trying. :worship:
damnit, you sprung me :P jks
Yeah my mate was saying that the ecu was crap, i reckon i'll buy it and fix it up, i want a car i can pull down and rebuild easily so i can learn, ain't gonna do it with my line, that's my daily. I may then sell it to a mate for his 1st car.
Thats not a bad idea, the only thing I would be concerned about is the heat generated from the amp and the computer. you may be better off putting the amp in a conventional position like on the back of the rear seats or under the passenger seat - otherwise you might need to think about mounting a fan inside the wheel well under the false floor
Jack88 knows a great deal about maximising position, I suggest you give him a msg and send him some pics n see what he recommends
+1 for his build quality too
-D
Edited by Dohmar
-D
Thanks for the suggestion, gives me something to think about now. I was going to use the guys at Strathfield at Noarlunga for the install, but i'll message Jack later when i am going to do the install.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
