one of these turned up today!
http://www.radiogearpro.com/main/product_i...ebad7423f80a703
its a 5 watt handheld UHF,i bought it from ebay, originally its only ment to operate from 400 - 470 MHZ of course this is of no use to me here, aus CB is from 467ish - 477.400 MHZ so a change here and there internally has now unlocked the radio to be able to work from about 130 MHZ - 520 MHZ.
Overall the unit is very small for its features and has a nice solid feel to it,has a good backlit screen too,considering the unit only costs $90 incl shipping its a great buy. its made my day so far :ninja:
I just got a letter in the mail from Shannon's Insurance about a competition they are doing. Head over to here to sign up, and more details....on the same day i take out a policy too :ninja: , if only i waited a few more hours to get that letter first.
Changing pumps in my Stagea. Does anyone know exactly what this "valve" purpose is? It looks to be 'incomplete' or damaged?
Pic:
Okay, the pic is a bit blurry, but its the best I can do this time of night.
Its right off the pump. I'm now fitting a Bosch pump and need to know if I can just get rid of this "valve"?
Anyone? :ninja:
have fun listening at truckies swearing...
LOL would you believe we did the same thing?!? Yesterday we took out a new policy at Shannons, today got that letter!
If thats all i was going to use this unit for i already had other cheapie .5watt ones around that i could use....
The new one was bought for its higher power output, extra features and its ability to transmit and recieve on comercial frequencies.
Edited by Jack88
If your around regency park, you may still be able to listen to some whack job swearing and going off his nut on the radio. When i was at tafe, a mate (who is on these forums), had a cb radio in his car, and we listed to the guy going off his nut.
Well we just got home from David Copperfield at the Entertainment Centre - WOW what a show! Not sure it was worth $300 for our seats, but was pretty awesome nontheless!
And then off to Hale and Pace at the Festival Theatre tomorrow night .... lucky me!
how far down south do you live Daniel and how soon do you need it on the road?
Me or Matty could tow it up for you possibly.
if i had a winch on my trailer we'd be right..........but i dont :) and i dont hav my winch on the car yet (or a front towbar point for that fact)
hey Matty, I was actually thinking of just pulling him up the driveway with a snatch strap (or tree trunk protector) connected to a tow hook on my truck.
I'm hoping this place he's going to is just around the corner though.
$300? wow, i hope you were close to the front for that!
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
