one of these turned up today!
http://www.radiogearpro.com/main/product_i...ebad7423f80a703
its a 5 watt handheld UHF,i bought it from ebay, originally its only ment to operate from 400 - 470 MHZ of course this is of no use to me here, aus CB is from 467ish - 477.400 MHZ so a change here and there internally has now unlocked the radio to be able to work from about 130 MHZ - 520 MHZ.
Overall the unit is very small for its features and has a nice solid feel to it,has a good backlit screen too,considering the unit only costs $90 incl shipping its a great buy. its made my day so far :ninja:
I just got a letter in the mail from Shannon's Insurance about a competition they are doing. Head over to here to sign up, and more details....on the same day i take out a policy too :ninja: , if only i waited a few more hours to get that letter first.
Changing pumps in my Stagea. Does anyone know exactly what this "valve" purpose is? It looks to be 'incomplete' or damaged?
Pic:
Okay, the pic is a bit blurry, but its the best I can do this time of night.
Its right off the pump. I'm now fitting a Bosch pump and need to know if I can just get rid of this "valve"?
Anyone? :ninja:
have fun listening at truckies swearing...
LOL would you believe we did the same thing?!? Yesterday we took out a new policy at Shannons, today got that letter!
If thats all i was going to use this unit for i already had other cheapie .5watt ones around that i could use....
The new one was bought for its higher power output, extra features and its ability to transmit and recieve on comercial frequencies.
Edited by Jack88
If your around regency park, you may still be able to listen to some whack job swearing and going off his nut on the radio. When i was at tafe, a mate (who is on these forums), had a cb radio in his car, and we listed to the guy going off his nut.
Well we just got home from David Copperfield at the Entertainment Centre - WOW what a show! Not sure it was worth $300 for our seats, but was pretty awesome nontheless!
And then off to Hale and Pace at the Festival Theatre tomorrow night .... lucky me!
how far down south do you live Daniel and how soon do you need it on the road?
Me or Matty could tow it up for you possibly.
if i had a winch on my trailer we'd be right..........but i dont :) and i dont hav my winch on the car yet (or a front towbar point for that fact)
hey Matty, I was actually thinking of just pulling him up the driveway with a snatch strap (or tree trunk protector) connected to a tow hook on my truck.
I'm hoping this place he's going to is just around the corner though.
$300? wow, i hope you were close to the front for that!
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
