No pics tonight but will get some tomorrow... as for the specs, twin pipes all the way to the cat, custom made by Andrew at AM Performance, can't recommend him enough!
You got the AM hi flow cat as well? Getting shit all over the rear bar?
I went to Pearl Jam at war memorial drive tennis courts, what, 14yrs ago. Then thebarton 12yrs ago.
1st one was unreal. Same yr saw SilverChair at the adelaide uni bar. woot
I went to that - it was on my 21st birthday. Bludged uni and spent the day lining up to get a spot right up front. Only problem was that friends came and gave me presents so I had all this stuff to look after. I was in the second row with one of my female friends directly in front of me and I had my arms either side of her, holding the fence to try and prevent her from being crushed. I withstood the Meanies set and about 10 songs by Pearl Jam before exhaustion & dehydration meant I had to leave and get a drink & rest. Had a great night though, not a typical 21st party.
Edited by writeoff
Hey Dion :mrt: been waiting for you to come online.
No Swineflu anymore, yesterday was my first day out of quarantine!
Did you get the measurements for the gtr bar for me? :)
Oooops I forgotz. I will do it today when I get home, if you haven't heard from me by 4 chuck me an sms.
My first car I was an SLR5000 .Anyway I was looking the other day on ebay to see how much i could get for an SLR ashtray and i was amazed at how much these cars go for these days over 20k for a rust bucket. I wish i had of kept it. It was the only car i sold and made money on it. I sold it for 8000 about 10 years ago and if i kept it they reckon it would be worth about 50000 now.
Thought you might like to see my latest purchase, the new Work Emotion 11R rims, just released in Japan. I'm hoping I'll be one of the first in Oz to get them on a car. I bought some in matt black, 18x9.5 +20 all round for the Evo 8. Should fill the guards reasonably well lol...
I'm a big fan of the SLR and was looking at buying one last year ... but the high price tag scared me off. :D
Still want one tho. Maybe a replica :P
Nah, stayed with my Apexi cat, like Andrew said, no point buying one if I already had a good quality one....
Awesome rims there Kristian, what they going on?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
